Listen to the 3xp exclusively for a week and then go back to the Thx789.Trigger warning - I'm gonna put out what I think is going to be an unpopular take but I'm doing this not to offend anyone, but to ask for advice.
I've just spent the last hour switching between my Soloist 3XP with supercharger and a regular old THX 789. Both are hooked up to a Denafrips Aries II. Started this experiment with Focal Clears then switched to Aryas which are known to be amp dependant.
I cannot hear a difference between the two amps - not in tonality, clarity, stage... Nada.
I'm wondering what I just spent three / four times the price of the thx for.
A couple of points. I assume I'm using the stock Op-Amps. I haven't opened it yet but will soon as I have a faulty select button in then soloist volume dial. Burson are sending me a replacement part. Will see how that goes.
Back to the main point/question, if there is a difference between the Soloist and the 789 I really seem to be missing it. Can anyone here who has compared both amps properly (i.e. using the same DAC and headphones) tell me what audible differences you've heard? Song references would be great so I can look out for them.
I was expecting a warm and engaging "class A" sound (whatever that means). As a further test I've hooked up the same DAC and headphones to my Tor Balanced... now that is a warm and engaging experience! Lush!!!
The soloist is my first class A solid state so I'd really like to understand what most people look for in these amps Vs a class D or other class (in addition to differences Vs the 789 from anyone who has run that test).
Thanks in advance
Also try 'headphone power amp mode' on the 3xp.
