I have been living in a lie my whole life...It is the other way roundvivids
-red, classic - orange![]()
Burson Conductor 3 Performance & Conductor 3X Performance
- Thread starter escalibur
Well I was going to upgrade to the 3XR but they are backordered at my dealers.The ONLY reason to upgrade is simply that T.O.L.mentality but after a LOT of listening,thinking about what end game cans I want & other factors I'm keeping the 3P & just tonight ordered Sennheiser HD800S headphones..I'll break them in a few hundred hours using the 3P & after that decide if they need a tube amp as I still have funds left over from NOT getting the Empies($3000.00)..I figure the $1500.00 left in the play $ fund should get me an end game tube amp that will thrive with the Burson...
i enquired with burson audio about this some time ago. they said that they are assembled in melbourne.
Thanks for the insight, appreciate it!
Does someone know how C3XP XLR outputs at backside works? Are they variable volume controlled so I can add active speakers to those connectors or do I must use RCA instead?
You can change if they are variable out or line out in the menu via the volume wheel but it effects both the rca and xlr outs and mutes the headphone jacks. This is not able to be changed with the remote.Does someone know how C3XP XLR outputs at backside works? Are they variable volume controlled so I can add active speakers to those connectors or do I must use RCA instead?
pbarach
- Aug 2, 2006
Has anyone tried the 3 Performance or 3X Performance with Focal Clears?
I was thinking that same. Not happy with my HD660S with this unit. Read about some reviews and watched some videos about Clears and they may be headphones with my taste. Any feedback would be nice about those headphones with this unit. I wish some more bass and slam with energetic synergy compared to HD660S. Offcourse nice mids, treble extencion and open soundstage and great imaging. Can Clears do that?Has anyone tried the 3 Performance or 3X Performance with Focal Clears?
raoultrifan
The audio amplification part from the C3X has just moved recently into the Soloist 3X: https://www.head-fi.org/threads/bur...wpc-xlr-with-muse72320-volume-control.941047/ or here: https://www.head-fi.org/showcase/burson-soloist-3x-performance.24591/ . Now this is a really good step-up after Fun.
escalibur
- Feb 9, 2016
Has anyone tried C3P with Sparkos' opamps? I wonder would they make any audible difference.
- Aug 10, 2010
Mikes review of the Burson Conductor 3 Performance is now published
https://headfonics.com/burson-conductor-3-performance-review/
escalibur
- Feb 9, 2016
Interesting read. Thanks for sharing!
walkmanforever
- Jan 24, 2011
I received the Conductor 3XP this Monday and pairing it with the Arya, both are burning in and this setup is euphonic! Currently driving via SE out using the stock Arya cables.
Questions:
Has anyone used the balanced out and found noticeable difference in SQ and SS per other users' opinion?
Is it safe to plug in the headphones in High gain mode when the volume is on mute or only when the volume is 0?
Is there any break in period for the 3XP? FYI, I heard smoothning of the upper frequenceies after 10+ hours of use. Any opinion on this?
Questions:
raoultrifan
It is safe, but it makes more sense to pause the music playing instead of muting the volume.Is it safe to plug in the headphones in High gain mode when the volume is on mute or only when the volume is 0?
walkmanforever
- Jan 24, 2011
Thanks a lot. Also, I have read that Class A amps need a warm up time of 30 mins+ in order to sound their best. Whenever i listen to the 3xp after a cold start it sounds a little harsh in the highs. I keep it playing for an hour post which the sound is smoother/richer. Don't know if it's just me or is there anyone on the same boat?It is safe, but it makes more sense to pause the music playing instead of muting the volume.
Sam Spade
Hi all, i've started a thread on swapping op amps with Burson equipment. I'm getting some V6 classics and Sparko pros.
I have a Conductor 3x ref but I figure the reference models are similar.
https://www.head-fi.org/threads/spa...-actually-any-opamps-into-burson-gear.947874/
