Sam Spade
I’m looking to order some Sparko opamps for my Conductor 3X Reference. Alex from Burson advises me: The Conductor 3XR uses 4 dual opamps. 2 for the I/V stage and 2 for L/P stage. Change over the V6 Classic dual in the LP stage will be fantastic for your unit.
Sparko's top model is the pro SS2590 https://sparkoslabs.com/product/pro-discrete-op-amp-ss2590/
They are single op amps so I’ll need 2 by 2 https://sparkoslabs.com/product/pro-to-dual-dip8-adapter/
The PRO to DUAL adapter allows the SS2590 to replace Dual DIP8 op amps. So it’s a stack, Dual dip 8/ SS2590/ Dual dip 8/ SS2590
The Sparkos are wider than the Bursons, so I’ve also ordered the Burson 35mm Extension Lead x 2, so hopefully that, or some DIP8 sockets will lift the Sparkos up to allow the Sparkos to fit. https://www.bursonaudio.com/product/35mm-extension-lead-x-2/
If anyone has any advice on whether the sparkos will fit in my Conductor 3X reference let me know. But I am going to take the lid off and have a look and measure.
Another question. The V6’s are 29mm tall. Does anyone know how much extra spare height is there between the top of the Op amp and the case lid?
I’ve had advice that the Sparko SS3602 dual Discrete Op Amp will fit. But I’d just like to really make sure the Pro doesn’t fit first before buying the SS3602. Why not go for the best?
My C3XR came with the Vivid V6. I've ordered a pair of the Classic V6 to try too. Once I get the Sparkos and have listened to all three I'll post a review.
Also, does anyone know why Burson say don't change the Op Amps in the I/V stage, but replace them in the L/P stage?
Cheers
Sam
Cheers
Sam
