shadow84
- Feb 7, 2010
is it possible to tak a pic of you wearing it? would like to see how does it look like wearing over-the-ears.. and does it fit the sony hybrids? thanks a lot.
Quote:I haven't messed around with my clip+ in nearly a year.... And when I did mess with it, I used a setup that was suggested on a forum. There are tons of settings to play with, but it can get complicated and it is easy to screw up. I played it safe.
Sent from my SGH-T989 using Tapatalk 2
So did you get a balanced sound from the r1 because you used the settings (I suppose that is eq setting?) on your clip+ or is it balanced on its own?
If you go over to mp4nation.net, there's another review by a mod called maderin1 that shows a picture of him wearing it. It also points out that there may be a problem with the R1's with a remote. It seems like the remote part sits a little high when the R1's are worn over the ear. Check out his review, it's a good one
Do you mind posting the link as I can't find it anywhere.
Edit: Also can you compare the differences in bass and mids between the r1 and the b2 in more detail? Thanks.
Here's the review although you might need to register to read it and see pics.. http://www.mp4nation.net/forum/f46/brainwavz-r1-mini-review-dual-dynamic-driver-earphones-18377/
Hey D2K.. As there been any changes to the R1's sound since you've been using them compared to the sound right out of the box?
Quote:If you go over to mp4nation.net, there's another review by a mod called maderin1 that shows a picture of him wearing it. It also points out that there may be a problem with the R1's with a remote. It seems like the remote part sits a little high when the R1's are worn over the ear. Check out his review, it's a good one
They do tend to be an addiction, that Brainwavz lineup
Trying my best to resist. Those who have ordered should be receiving their R1 soon. Please post your impressions before the offer expires on Monday. I still enjoy my M4...
Well if the R1 sounds anything like the M4, I won't like it. So I hope it doesn't sound like the M4.
