My preference too!! That cosmic black looks juicy
Nah... Punk Pink all the way
@razzer001 That makes a lot of sense. Thanks for the explanation!
@peter123 They're good. Extension is better than the few BA-only iems I've got (B100, B150, UE600, XBA-2) but short of what you'd expect from a good dynamic. It's not too far off the FLC 8S with my preferred red/grey filters, mind you I find the low end of the FLC 8S underwhelming for a dynamic, especially in terms of impact. B400 hits with more speed and authority, it's just missing that super low end rumble.
Is the XBA-2 the same as XBA-A2?@razzer001 That makes a lot of sense. Thanks for the explanation!
Yes - it’s very articulate. Doesn’t have as much treble extension as the Dipper - but that’s one of its charms. Does pretty much everything right and the fit is phenomenalThanks again mate!
@Brooko
After getting used to the Big Dipper I find many of my other IEMs to come across as a bit muddy/blurry. Do you think that the B400 could be a good option for situations where I don't want to bring the BD?
Please also share some thoughts how you compare these with A4(with black +black combo),Yes - it’s very articulate. Doesn’t have as much treble extension as the Dipper - but that’s one of its charms. Does pretty much everything right and the fit is phenomenal
Well you lose the ability to tune, and so it depends on how you tuned the A4. In terms of comfort, the B400 is among the most comfortable I’ve tried. I tend to like a more balanced signature - so the B400 ticks all my boxes. If you like a more v shaped signature, then you may like the A4 more.Please also share some thoughts how you compare these with A4(with black +black combo),
Do you think it is a clear upgrade to A4 ,????
Thanks .
Thank you very muchWell you lose the ability to tune, and so it depends on how you tuned the A4. In terms of comfort, the B400 is among the most comfortable I’ve tried. I tend to like a more balanced signature - so the B400 ticks all my boxes. If you like a more v shaped signature, then you may like the A4 more.
If you don’t mind a little EQ and like a V shaped sig, then definitely B400
What tips are those? They look dope.Nope. XBA-2 is one of Sony's original XBA models.
