edsjo
- Jan 4, 2017
That's what I thought... there are some reviews a few threads back that say they sound great wired to an external DAC/ AMP. But the his happens as soon as i plug the included cable into the headphone with no DAC/AMP or source plugged in yet at the other end. So no double conversion happening.... tells me it's something internal or with the analogue in portion.
Maybe there is no double conversion if you have no signal on the attached cable, but as soon as you plug in an analog cable (even if it has no signal) the PX goes into active analog mode. Either it then passes the analog signal (even if non-existent) to the amplifier section or it performs an ADC conversion and then feeds the signal to the regular DAC and amplifier section. Regardless of which, it has to do something as it cannot be used in passive mode. My guess is that they didn't spend enough resources/money to make the noise floor lower here, probably as this is not the default use case. Or there is a quality control issue on the analog input part of the headphones.
