bedlamite
- Feb 17, 2002
These are wireless ANC cans, first and foremost. If you aren't planning on using these functionalities on a regular basis, I'd advise you to spend that cash elsewhere. The PXes certainly aren't cheap, and you could pick up something like a HD650 for the same amount of cash if you want something for proper critical listening.
ANC cans will almost always sound strange with the canceling function disabled, there's quite a bit of sound processing to going on to make them work with the mics on the cans, and when you turn all that off the result is usually a garbled mess.
