Soundizer
- Dec 29, 2015
Thank you. The volume control is much more dynamic after the update with greater range at low volumes.
They have a good quality clamp but... insanely hard to remove??
So out of blue, my P7W is not turning off automatically after 10 mins. Any way to fix this? FYI, I tried resetting by pushing the button in for more than 6 seconds and re-paring to no avail.
There is an update out for them here:
http://bowersandwilkinsus.custhelp.com/app/home/p/281.
You could try updating them to see if it fixes the issue you are having.
Quick update... I haven't brought my p7w to work today so I am listening to my mates dre studio wireless 2.0.
Volume is considerably lower. Sounds nowhere near as spacious as my p7s. Congested sound is to my ears making the meat of the music sound off/recessed in comparison. Bass is nowhere near p7w. Im missing little details in songs I'm a now used to. In short, the p7w absolutely smokes it.
This is the same mate who was going to buy the p7w in my earlier post. This is wireless as he hasn't brought the cable in. For this price, I'd be spewing. It's like the music has lost a lot of musicality for some reason.
Don't mean to sound like I'm hating but ye... Interesting. I have the earphones with me that came with the s8 and honestly I much prefer them.... Crazy
the word is bass not "base"
It's not a burn in thing, you simply used to a different sound signature it will take time for your brain to get used to it, or just look for something else if it keeps bothering you.
I would suggest giving it a bit more time to burn in like 72 playing hours. if that doesn't change, I've heard that the firmware update on the P7W does quite change the signature a lot to the old wired P7. let me know it does indeed calm down upon burn in or firmware update. I do have right now the old wired P7 and like you loved the signature it gives. the only issue I have with it is that it is wired and gets in the way. I just hope that the firmware does the job.
http://bowersandwilkinsus.custhelp.com/app/home/p/281Which firmware update is that?
