kairad
- Dec 26, 2012
I was thinking about grabbing one of these soon. Should I wait for an upgrade from b&w since its already 2.5 years old? Any others to consider?
^some studies suggest, though it is mostly alternating magnetic fields that pose a problem. If you care about that buy ultrasone or Stax.
The field strength can actually be very strong with headphones, 10 times stronger than the upper limit of say your computer monitor
No studies I have heArd about suggest it is dangerous. Only side effects
Ok, so i have had the P5 for two years now. The cable really sucks. Within the first month, the cover to the volume control came off. And I don't even use it because I don't have any apple products. Recently the right driver seems to stop delivering any low end note. All the mid to high frequency can be heard, but no bass. Is this a driver issue? or cable? Anybody have this problem?
Are you sure you don't have earwax buildup? My IEM's were not sitting in my ear fully yesterday and I tried getting rid of some of the wax around the ear canal by using some ear drops that are supposed to help. That is what did the trick in my case.
Improper seal will kill the bass with iems.
Impacted ear wax will muffle the sound.
