audio dilettante
I think this is all good advice. When I switch to PX8 after days on the Bathys and vice versa it always takes time to adjust.
Simple answer, yes, but whether the clamping pressure remains an issue for you even when they have been used a bit is difficult to say. Out of the box, I found the PX8s to be a tad uncomfortable, but this disappeared after a few days use in anger. Whether it was actually because the clamping force dissipated, that I got used to wearing them or a combination of both is impossible to say, I now find them one of the more comfortable of the premium headphones, and happily wear them for hours in a day, and often with reading glasses. I say this because, almost certainly, lighter (but well built) headphones are less likely to pose comfort issues, and in that I would include the Sony MX range, Bose Quiet Comforts and the Anker Soundcore headphones.Got my pair of Px8 yesterday. While I love almost everything about them the high clamping pressure is quite uncomfortable on my admittedly huge head so after a couple of hours I just want to take them off. Before that I've been using a cheap pair of Anker Q30 which I can wear all day every day no problems. Can anyone who had a similar experience tell me if this gets better with time?
Otherwise what alternatives do I have that are less tight and which ones should I definitely avoid?
This is a really wise advice that i completely agree with!Which HPs were you mainly using prior to the Px8? Looking at your sig, if it was something like the HD800s/Aonic, I can understand. That was the case for me. I typically have a strong preference towards 'neutral' sounding cans e.g., HD600, NDH-30, S4X, MM-500, T3-01 etc.., so when I first tried the Px8, it felt completely off. It sounded very congested with overblown mid bass. But once I got acclimated to the new sound, it was rich and overall pleasing sound, albeit still a bit too intimate staging wise. Give it some time for your brain to catch up. If it still doesn't work for you, return it. I wouldn't pay attention to other reviews/impressions. If you take away all the sponsored reviews, hype, and biases, ain't much to look at anyways. If it ain't for you, it ain't for you. No need to conform yourself to "perceived" consensus.
Have you tried 'gently' stretching the headband? After going thru two sets of px8, one thing i noticed was the different clamping force. One was very comfortable out of the box, and the other one was tight on my head. And I know this for sure because when I removed them from the case for the first time, one was touching at the earcups, and the other one was farther spread apart. It doesn't take much force at all to slightly widen the headband to better form to your head IME.Got my pair of Px8 yesterday. While I love almost everything about them the high clamping pressure is quite uncomfortable on my admittedly huge head so after a couple of hours I just want to take them off. Before that I've been using a cheap pair of Anker Q30 which I can wear all day every day no problems. Can anyone who had a similar experience tell me if this gets better with time?
Yeah I have primarily been using a JBL TourOne, just for the ANC. My Momentum3, qc35 for travel, then at home my HD800S, Aonic and H95, sometimes my NAD Viso HP70.Which HPs were you mainly using prior to the Px8? Looking at your sig, if it was something like the HD800s/Aonic, I can understand. That was the case for me. I typically have a strong preference towards 'neutral' sounding cans e.g., HD600, NDH-30, S4X, MM-500, T3-01 etc.., so when I first tried the Px8, it felt completely off. It sounded very congested with overblown mid bass. But once I got acclimated to the new sound, it was rich and overall pleasing sound, albeit still a bit too intimate staging wise. Give it some time for your brain to catch up. If it still doesn't work for you, return it. I wouldn't pay attention to other reviews/impressions. If you take away all the sponsored reviews, hype, and biases, ain't much to look at anyways. If it ain't for you, it ain't for you. No need to conform yourself to "perceived" consensus.
i first wanted to see if after eq I liked what I heard enough to potentially give time for more of that adjustment. I'm a believer in breaking headphones in letting music play from them, so we'll see how it goes.:Agree with this entirely. Give it a period of adjustment, and, also, I do think a period of running in the headphones (playing music through then without listening) is also probably advised. However, if after a reasonable listening period and listening to your favourite music, the PX8 don't appeal to you, there are different sounding alternatives out there..
My experience with the Px8 is that they were quite comfy from the start but that they improved greatly over the first week or so of heavy use. The ear cups formed to my head. The headband can be stretched carefully but I didnt need this myself (but did it with other B&W cans). Now PX8 are some of the most comfy headphones I have tried, surpassed only by Bose QC35…Got my pair of Px8 yesterday. While I love almost everything about them the high clamping pressure is quite uncomfortable on my admittedly huge head so after a couple of hours I just want to take them off. Before that I've been using a cheap pair of Anker Q30 which I can wear all day every day no problems. Can anyone who had a similar experience tell me if this gets better with time?
This is true. I have the largest head in my peer group and found the clamping force to be most agreeable on the PX8. Mine haven't loosened though so if they don't fit you now, I doubt that'll change.My experience with the Px8 is that they were quite comfy from the start but that they improved greatly over the first week or so of heavy use. The ear cups formed to my head. The headband can be stretched carefully but I didnt need this myself (but did it with other B&W cans). Now PX8 are some of the most comfy headphones I have tried, surpassed only by Bose QC35…
I would say that as long as your ears are not too big for the cups it should be possible to get a really good fit.
i haven't had the same experience with this, mine have felt great on my head, up there with my QC35, Momentum3 etc.Got my pair of Px8 yesterday. While I love almost everything about them the high clamping pressure is quite uncomfortable on my admittedly huge head so after a couple of hours I just want to take them off. Before that I've been using a cheap pair of Anker Q30 which I can wear all day every day no problems. Can anyone who had a similar experience tell me if this gets better with time?
It is easy to stretch the headband but impossible to bend it back if too loose. One way to do it carefully is to place the headphone over a set of books with suitable thickness.This is true. I have the largest head in my peer group and found the clamping force to be most agreeable on the PX8. Mine haven't loosened though so if they don't fit you now, I doubt that'll change.
I'm sure it can be done but not advisable in my opinion. The leather on the PX8 is delicate enough with stretching it on some hefty tome! Wouldn't do it myself.It is easy to stretch the headband but impossible to bend it back if too loose. One way to do it carefully is to place the headphone over a set of books with suitable thickness.
Well I am not talking about any violent stretch per se, but the ”book method” is very gentle and shouldnt be a problem. I do it with most headphones.I'm sure it can be done but not advisable in my opinion. The leather on the PX8 is delicate enough with stretching it on some hefty tome! Wouldn't do it myself.
