samthegreat4
- Jun 20, 2013
The good advice keeps coming.
I just ordered a Fiio E11, because I'm just so damn curious whether an amp will really do anything to the sound and because I need to turn my DAC volume up pretty high in order to be able to get volumes I want.
Let's see
Would you say: hold off on ordering the DT880 as comparison and sending one of 'em back later?
Some great advice on this thread.
OP - as another owner of both (HD600 & DT880) - here's what I would advise for a start.
- Put your Samson away. Don't use it for at least a week.
- Use the HD600 exclusively for a week
- After a week try your Samsons briefly again.
What you should find .......
- The Samsons will sound excessively and unnaturally bright
- The HD600s by now will sound very natural
- You should now also notice that the HD600 treble is not 'veiled', and that it's not missing any details.
I really can't understand the comments on the famed Senn veil. All the detail that I get from a headphone like the DT880 is still there in the HD600 - it just doesn't have a spotlight shone on it
Don't get me wrong - I love both the DT880 and HD600 - but they have two very different presentations. One is very bright (actually almost unnaturally so), and the other is slower - but IMO is more life-like, with far better presentation of tone and timbre (HD600).
If you are going the DT880 route - you will need a reasonable amp with it. And even the HD600 (although they are relatively easy to drive) IMO scale well with amping. You can get them to reasonable volume straight out of an ipod - but via my NFB-12 or Little Dot I notice no murkiness, cloudiness, or veil.
If after a week you still don't like the HD600 - get rid of it and either go DT880 or K701/702/Q701. They may be more to your liking.
Let's see
