bookshelf speakers vs studio monitors?
Jan 20, 2014 at 8:16 PM Post #31 of 286
my only thing with the ants is the wattage seems kinda low. its like the same wattage im using now. i def would like to improve on sound volume if i can.
Amplifier power only tells you half the story and doesn't help a lot by itself. How loud speakers will get does depend on the amp, but it also depends on how sensitive the speakers are. For example, my Ascend CBM-170 SEs are rated 89db 1w/1 meter. That means with 1 watt of amplifier power, they will reach 89db when listening from 1m away. Compare those to the ARX A1b I mentioned, which are 86db 1w/1m. 3db difference.
Now that might not seem like much. But the thing is that it takes double the amplifier to produce 3db. So a 50 watt amp only produces 3db more than a 25 watt amp; the CBM-170 SEs will be as loud with a 25 watt amp as the ARX A1b will be with 50 watts of power.
M-Audio claims 101.5 dB @ 1 meter RMS for the AV40s; Adam F5 is rated ≥106 dB peak. Usually, RMS will have more power output at peak than what is specified. So you may not get much more volume out of the F5s than the AV40s, although most likely the F5s should have better drivers that would maintain their composure better at higher volumes. This all assuming the manufacturers have been honest, which is often not true. Specifications are often exaggerated by audio companies.
Jan 20, 2014 at 8:18 PM Post #32 of 286
I always tell people its an AMPLIFIER not a WATTIFIER
Jan 20, 2014 at 8:51 PM Post #33 of 286
very tough decision, luckily i have like 3 weeks to decide which direction to go.  swan peeks my interest. ive heard they are very good. like the Swan m200mkIII. just another option to add i guess heh. i also like the idea of buying my first amp or reciever. seems like a fun idea. so many choices lol.
Jan 20, 2014 at 9:03 PM Post #34 of 286
The Swann stuff I've heard was fantastic. But they get pricey
Jan 22, 2014 at 11:23 PM Post #37 of 286
  These 8 inch monoprice studio monitors have peaked my interest at only $250 hmm... im gonna have to do some comparisons.
Better to do go with a 5 or 6" in a 2-way design, although the ideal monitor IMO would be a 3-way with a 2" or 3" mid and a 5-7" midbass driver.
An 8" driver beams quite a bit (don't know what your seating distance is) and also has trouble resonating fast enough to meet up with a tweeter. There was a member on AVS with a Dynaudio Special 25 who spent over $3k on a DEQX active crossover with 300db/octave crossovers and still couldn't get the 8" woofer to perform in the mids as well as the 6" on a Dynaudio Confidence C1 (both speakers use the same tweeter).
Jan 23, 2014 at 12:52 AM Post #40 of 286
No problem! Was looking around for new monitors also. Currently have KRK RP5 G2 and want to get something better and the LSR305 seems to be that good!
Also, I accidentaly linked the 2nd page instead of the 1s of that impression thread.
Jan 23, 2014 at 2:08 AM Post #41 of 286
Go with monitors partly for convinience and partly for there "revealing" nature. What kind of sound signature do you like? Also what type of music do you most listen to? That can swing your decision too.
Jan 23, 2014 at 9:43 AM Post #43 of 286
One speaker model being more revealing than the other is an indication of difference in speaker quality. Has nothing to do with passive vs active.
Jan 23, 2014 at 10:14 AM Post #44 of 286
Active speakers are bi-amped which equals less distortion.
Active speakers allow better optimisation of the crossover.
Active crossovers increase headroom because the bands are separated reducing the chance of distortion.
Active monitors have amps specially matched to the drivers. Better damping.
Active monitors can connect the bass driver mechanical motion in the amps feedback loop. Better high freq response, reduced ringing, reduces driver distortion.
Passive crossovers waste energy as heat.
All else being equal active always beats passive. That's why it's almost impossible to buy high quality, new monitors that aren't active any more.
If you can afford it that's what you want. Active.
So yeah. kids right. Actives will be more 'revealing' because they are by nature more accurate, produce less distortion and play louder.
Jan 23, 2014 at 12:36 PM Post #45 of 286
Not true.
Passive speakers can be bi-amped also. Passive speakers can have just as good of a crossover. Headroom is based on making sure the AMPS have enough power available. Passive speakers are typically used in a lot of mastering suites, where they need to most "revealing and accurate" speakers.
