Omg, I would have saved so much time if I just remembered this conversation from May..Sound dropout every few seconds on USB out.
![Man facepalming :man_facepalming: 🤦♂️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f926-2642.png)
I'm still pissed at Bluesound not delivering on their promise regarding USB out. They acknowledged the issue later on but never bother to fix it.Omg, I would have saved so much time if I just remembered this conversation from May..![]()
Damn,I'm still pissed at Bluesound not delivering on their promise regarding USB out. They acknowledged the issue later on but never bother to fix it.
I guess if I am not using roon then it should be ok? Spotify tidal Qobuz?Ahh so it would still work without dropouts if using coax?
Yep, this only effects Roon.I guess if I am not using roon then it should be ok? Spotify tidal Qobuz?
I tried it and now my USB out doesn’t work at all with my Yggy. I don’t use Roon, so I can’t comment on that. Tried a factory reset and no luck. Is usb working for anyone else on 3.20.25?Yep, this only effects Roon.
In other news, just downloaded BluOS 3.20.25: it says among other things "miscellaneous bug fixes"
I hope the Roon bug was squished. Anyone try it yet?
My usb out works just fine with a Woo DAC/amp connection and 3.20.25I tried it and now my USB out doesn’t work at all with my Yggy. I don’t use Roon, so I can’t comment on that. Tried a factory reset and no luck. Is usb working for anyone else on 3.20.25?
Yep! You'll still be able to adjust volume on the Node when using an external DAC.Hi, i am currently using node n130 directly to power amp and controlling volume via node. I am thinking to upgrade dac and put bifrost 2/64 in chain between node and power amp, So i was wondering if i still control volume via node would it be fine?
So would node volume control work fine?
Thanks
Hi actually my bad i did not asked the right question. What i meant is if i control volume through node will it work for schiit bifrost or bifrost will keep pushing full 2v to my power amp?Yep! You'll still be able to adjust volume on the Node when using an external DAC.
Depends on how you intend to connect the node to the bifrost, if using coaxial/optical you can control the volume on the node as long you don't toggle the fixed volume option within the BluOS app.Generally volume control is after dac in most of the chain but in my chain it will be before dac directly to power amp.
Ok, i will give it a try then.Depends on how you intend to connect the node to the bifrost, if using coaxial/optical you can control the volume on the node as long you don't toggle the fixed volume option within the BluOS app.
The USB output on the node is fixed volume, but some dacs still allow volume control from the node. I had a Topping dac that still allowed the node to control the volume, this is classed as a fault by bluesound.
I can't say if your Bifrost will allow volume control from the node using USB, it should work using coaxial/optical.
One thing to bear in mind is that fixed volume allows for a bit-perfect connection, volume control from the node my defeat that. It does on my dac if the volume isn't set to maximum then a 16/44 track will show on the dacs display as 24/44. Your situation may be entirely different.
