gimmeheadroom
No headamp, there goes the budget...I love the Bifrost 2. Right in your budget. Big upgrade to DAC in Node 2i as I have both and a/b tested them.
Most of my listening nowadays is over either Node 2i or B100S.Had a Node 2i in a cabinet doing nothing for two years since I moved and don't have the system it was a part of any longer. Was thinking I should sell it, but never did. For my headphone rig, I had been using my MacBook Pro usb to dac to amp. For fun I dug out the Node 2i and swapped it in place of the laptop and ran SPDIF coax to the dac. I want to say it sounds a bit smoother with less treble hash, but it's not night and day. Will have to A-B test a little more. On the other hand, with the Node I have less control, as the EQ function is horrible on the Node so I won't us it. On the MacBook I have SoundSource which I use sparingly but do enjoy having the ability to compensate for bass-weak recordings. Thoughts on Node vs laptop for HP listening?
I’m also using the Node as a transport out to a Bifrost MB. Do you hear any difference in sound quality between the Node and the B100S (as transports) ?Most of my listening nowadays is over either Node 2i or B100S.
They're good little boxes. I'm using my Node 2i as a transport though since I have an MQA DAC.
Have any of you who use the Node as a transport only with an external DAC noticed any sound quality differences between digital coax out vs optical?
I use an external DAC and have tried Optical to the Chord QUTEST ... my ears definitely prefer coax from the Node 2i.I have not compared, since I only use optical S/PDIF if I have no other choice.
Optical is inferior unless you have a ground loop or electrical noise problem. That is unlikely given the Node is not grounded.
Optical is rated 24/96 while coax is rated 24/192.
Same for me with the Gungnir MB. But that could just as easily be at the input as the Node output, so therefor DAC specific.I use an external DAC and have tried Optical to the Chord QUTEST ... my ears definitely prefer coax from the Node 2i.
Very good point. Have A-B'ed coax (DH Labs) and optical (AQ Cinnamon) today into the Bifrost MB. Coax definitely providing larger quantity of bass output. Is the optical midrange perhaps a tad clearer? Actually hard for me to tell. Could just be the increased bass of the coax creeping into the mids.Same for me with the Gungnir MB. But that could just as easily be at the input as the Node output, so therefor DAC specific.
Huh, that's weird. To be honest, the first thing I noticed when I started using coax out of the Bluesound months ago was that it sounded boomy and bass-heavy compared to where I had it before, using the analog outs. I'm starting to wonder about these boxesVery good point. Have A-B'ed coax (DH Labs) and optical (AQ Cinnamon) today into the Bifrost MB. Coax definitely providing larger quantity of bass output. Is the optical midrange perhaps a tad clearer? Actually hard for me to tell. Could just be the increased bass of the coax creeping into the mids.
I did the upgrade on my 2021 Node. IMO it was a worthwhile upgrade For a minimal investment.Curious if anyone else has tried the PD Creative power supply upgrade for the node 2i. A pretty straight forward diy project. Open up the node and remove the bluesound power supply and then replace it with the upgrade kit. No soldering required, a couple of screws and one connector harness is all it takes. You can then use an external 5v 2a power supply with the node 2i. Options ranging anywhere from a basic switchmode ps up to a LPS like the Sbooster. I found it to make a pretty significant difference using the Nodes internal dac.
