donunus
- Nov 12, 2004
Maybe non i2s dacs really benefit from gizmos like the thingee and the trends for good USB to spdif conversion
Originally Posted by donunus /img/forum/go_quote.gif Maybe non i2s dacs really benefit from gizmos like the thingee and the trends for good USB to spdif conversion |
Originally Posted by donunus /img/forum/go_quote.gif I think I2s is a process where from usb the data doesn't go through spdif any longer before it gets to the dac chip . Most usb dacs without i2s goes to some sort of converter to spdif then to the dac chip. So the coversion process from usb to spdif is what is skipped when having an i2s usb dac. So in your case, the thingee does that part for you instead of the internal conversion when you use the constantines usb. |
I just picked up a Thingie to use as a USB/SPDIF converter to run between my laptop and DacMagic. I'll report back after some A/B (with/without).
the real question is whether it's filled w/ gooey stuff for mass dampening or because they're ashamed of the $2 16/48 max PCM2704 IC being used
Regardless....the rule of thumb "if it sounds good it is good" very much holds. And the improvement for me over standard USB is quite clear.
I find it astounding that anyone would spend $180 on this +3yo obsolete 16/48 transport when there's MANY more capable transports within this price range. It's obviously using PCM2704, that was good 3 years ago indeed.
It's like someone buying an Audigy II for a soundcard...technology does evolve, especially in the computer world
Compared to what? You know as much as I do that the best is the enemy of the better. Regardless, I didn't mean to threadcrap, but I'm quite sure that an Hiface/Bravo/TeraX2 would kill this +3yo thing. PCM2704 isn't the best sounding chip in many ppl's experience.
Aren't we bit of a "chip snob"? (BTW...the chip specs aren't given...so did you crack one open or are you guessing what's in there?)
