RockStar2005
No, this is probably something you do yourself, plus this is an apple forum, itunes EQ sucks and has tons of distortion. Instead of adding confusion, just know that flat means no change at all.
Like I said, you would have to listen to the ella first before making a judgement on EQ, very few headphones have met my wants perfectly so I usually EQ, but your preferences are different from mine so I cannot say whether or not the sound signature of the ella is good for you even if I heard it
Ok, so iTunes EQ sux. Got it. lol
The thing is, it would have to sound PRETTY bad for me to say it needs EQ'ing, but you would prob know within a few minutes regardless I'm sure. I'm at best a novice when it comes to EQ'ing. I have some BASIC knowledge, but in terms of "perfecting" a sound, which to me means making it sound as natural as possible (though sometimes a lil extra bass never hurt no one lol), I wouldn't always know. It just shouldn't sound "constricted" is all, or TOO trebly. That tends to be what you get with the "Rock" setting, which I only use in the car but never on headphones (with exception to 3 songs with "Rock" minus some bass lol).
My concern is based on the AKG K551 I have................. on Flat or Off, the songs sometimes tend to sound kinda weak, and that's bad too I guess. lol I was hoping there's some way to tell if that might be the case with the Ella on Off, but apparently not. lol
Thanks.
