Tonymac136
I'm not judging. For what they cost you'd be silly not to. MH755s that is. Kebabs are variable in quality.
Did Blon manufacture this driver themselves or which brand is it?
Is it manufactured by themselves or which company manufactures CNT Drivers?
Thanks for at least acknowledging my question(s) .I wouldn’t really stress too much about it, friend.
If you know anything about Chinese manufacturing:
1. the entire earphone could be ODM’d by someone else (like TFZ).
2. They could be drivers made in a random generic driver factory.
3. Drivers sourced in Shenzhen but made by an unknown factory (parts bought based on ‘spec’ only).
4. Drivers made by a temporary fly-by-night factory (which does happen a lot).
5. The drivers could be custom contracted out to a specialized driver company (which there’s loads of them in China)
6. It could be custom-made using imported diaphragms/voice coils but assembled at a factory in China, etc.
7. It could even be more than 1 driver factory or supplier, as was the case with the KB Ear F1.
You’ll honestly never really know for certain.
Who actually manufactures the exhaust camshafts used in the Ford Mustang? It’s not Ford, but rather some other supplier (or even suppliers as in plural). Who knows, who cares? Individual suppliers are often carefully held company secrets, which cuts down on competition.
I would just concentrate on enjoying them
Just got my Blon 03. Paired with the Tripowin C8 cable and plugged to my ZX300 balanced output these sound pretty decent. So far so good, for 13.56$ these were a steal.
Fit with the L sized Spiral Dot + tips is fantastic though.I take it back, fit is good but the low end sounds bloated with the Spiral Dots. These really need foam tips. Crystalline Audio or Dekoni Bullets Mercury so far are the ones I prefer.
I think it's the best solution. I had several pairs of KZ IEMs, at some point the ZS6 cable died on me and I did not want to wait half a month to get a new one from China so used ZST cable that did not fit as the original one so I had to bend the pins slightly. Be careful!Speaking of cables, I bought a C8 cable from another company. The sound seems very good and I like the cable, but the fit on 1 side is nice and tight, while on the other side the BLON actually detached somehow this morning accidentally. It does fit and stay on, but it's not as tight. Is this likely an issue with the cable, the BLON, or ? I am thinking that if i separate the prongs on the cable a little more, very slightly, then when I insert them into the BLON it'll be a tighter fit and fix the issue. If thats a horrendous solution to this problem or if there's a better way to improve the situation, someone please let me know
Yes but it's not flush with the housing.Does the nx7 like plug fit the oppoty ?
I'll get the mkii if reviews are good and I like the mki.Anyone getting the tin hifi t4 or maybe waiting for blon 03 mk2?
