Thanks. Can I ask you a quick question? I can see in your sig you mention the BL03, the Tanchjim Tanya's and the E3000's. Given they're all of similar price (well, the E3000 is 2x the price but still affordable), how do they compare. I'm specifically looking for a set that has a wide soundstage and is slightly V shaped.
Tanchjim Tanya Versus BLON BL-03:
Both sets are harmanish, boasting superb tonality and timbre at the sub $30 USD region. Both sets sound a tinge analoguish and scale with amping, though the Tanchjim Tanya is harder to drive. Both sets also have subpar isolation. Perhaps the BLON BL-03’s midbass is a tinge more bloated.
The Tanchjim Tanya edges it in the timbral accuracy and technicalities department. The BLON BL-03, even though it has detachable cables, has a notoriously bad fit due to the too short nozzles. Hence, most people need to do spacer mods or use aftermarket eartips/cables to secure a better fit.
Thus, the BLON BL-03 may be closer to $40 – 50 USD if aftermarket tips/cables are factored in, whereas the Tanchjim Tanya is ready to go OOTB, no need to mess around or spend more on aftermarket gear for it. As such, I see the Tanchjim Tanya as a marginal upgrade and a better set in terms of investment.
Tanchjim Tanya Versus Final Audio E3000:
The Final Audio E3000 is rather L shaped, featuring a big nebulous midbass and a rolled off treble. The Final Audio E3000 is harder to drive than the Tanchjim Tanya.
The Final Audio E3000 has better technicalities when amped, in the area of soundstage, imaging and instrument separation/layering, though it has a poorer timbral accuracy than the Tanchjim Tanya.
Both sets are bullet shaped and have non detachable cables, but the Final Audio E3000’s cable is worryingly noodle thin, with more microphonics and no strain relief. Isolation is also poorer on the Final Audio E3000.
Final Audio E3000 Versus BLON BL-03:
Both sets have a muddy and slow midbass, with rolled off treble. As you have rightly pointed out, the Final E3000 is almost double the price of the BL-03, but if aftermarket cables and tips are secured to get a better fit for the BL-03, they may actually be around the same price.
BL-03 is more analoguish and has worse technicalities. Final E3000 has worse isolation, but a bigger soundstage. Final E3000 is much harder to drive. BL-03 has fit issues, but has detachable cables, Final E3000 has non detachable cables as above.
The widest of the soundstages among the above 3 is definitely the Final E3000. But you will need an amp with the E3000 due to the low sensitivity. Without amping, the Final E3000 sounds bad.
