Slater
After 14 years I thought I saw it all here?
Check it out
https://www.head-fi.org/threads/flip-tips-or-fliptips-prepare-to-have-your-mind-blown.906357/
This song is truly amazing on the BL-01?
Nice! They look like the E-Horn tips![]()
In a hazy half sleep, after dozing, I played this and thought 'sounds great on my Blon 01', and then suddenly realised I was listening on the Dunu Topsound M380. Actually it does sound great on these fixed cable, triple micro driver IEM's. Will give it some time on the Blon-01 when I fully wake up from my hazy psychedelic slumber (natural, not drug induced).No question there. The cure are great!
It is interesting how foam tips can change the bass in this song while using the BL-01?
Tips more drastic than cables and at times do more than EQ.For sure, tips can affect the sound signature, eartips are not just for fit/isolation/comfort, but they actually do change the frequency response and are a very overlooked part of an IEM. They can even make or break IEMs (case in point, BLON BL-03 with crap stock tips). I daresay you get more mileage in changing the sound via eartips than aftermarket cables.
The right tips are imperative to get the best sound from an IEM. In the case of the Blon-03 the difference between a pure silver cable and a pure copper cable, makes the difference to whether I want to listen to it or not.For sure, tips can affect the sound signature, eartips are not just for fit/isolation/comfort, but they actually do change the frequency response and are a very overlooked part of an IEM. They can even make or break IEMs (case in point, BLON BL-03 with crap stock tips). I daresay you get more mileage in changing the sound via eartips than aftermarket cables.
So what kind of change should I expect from buying eartips with same dimensions but of more rigid material?yup. material and nozzle width would change the EQ, while nozzle length of the tips would change the depth of the soundstage
