Redcarmoose
Is the Fiio uBTR good enough to drive these? I'm actually quite new to this hobby and I happened to get the Blon Bl01's since they we're recommended to me. ( are they actually supposed to sound screechy at the high's or is it a Unit Variance thing? ) you could also say i'm one of guys running these through my phone lol. also, may I ask what tips you use these with? the stock tips fit but i'm not sure if they are "correctly sealed". Thanks!
One of the easy ways to solve the riddle is after you feel your getting a good tight fit try a home amp.
Meaning, word on the street is many are not getting a good airtight fit with the included tips. That would mean you simply have to go into a collection of tips looking for alternative tips than what has been provided with the IEM box. After that you need an adapter to just try with any (home) stereo amp around. Also desktop headphone amplifiers will create the desired power to know if that’s a solution.
There is no guarantee that a home theater amp will get you the answers. Your better off trying to find an older class A amp from the 1970s or early 1980s before the manufacturers went to cheap OP amps for the headphone out. Something like that as a short experiment will fill you in if loss of correct power will be why your hearing what your hearing.
I can say without a doubt the BLON BL-01 is no where near screechy after burn in with the right tips and right amp.
I’ll probably have to start testing the BL-01 with the collection of gear I have. Meaning I’m already optimally driving it, but I want to know if entry level amps like the FiiO Alpen 2 E17K will have enough juice to cure these issues.
