Fat Larry
Yeah I looked it up and I'm wrong. It's the BL-01.I think it is still called BL-01 with the "-"
Can I ask BLON, assuming everyone else didn't already. What was wrong with calling it BL-01 MK2, BL-01 Pro, BLO-01 I guess or whatever else other headgear makers use to name direct successors of their old gear?Maybe they are using full width hyphen ' —"and half width "-" to differentiate.
I'm assuming whoever already ordered also owned the assumed predecessor and judge accordingly.
As I mentioned before old BL-01 looks like an earbud that someone shoved a front faceplate with an EXTREMELY short nozzle (Yes, it puts the infamous BL-03 nozzle to shame) in front of it to make an IEM and called it a day. Also hardwired so forget about using a balanced source if that's your thing.I didn't. In fact I've probably only owned the BL-03 for about a month and have spent most of that time trying to get them to fit in my ears comfortably. I bought the BL-01 because someone said they're an improvement on the 03 which i do mostly like the sound of, i am an absolute sucker for bang for buck performance.... and I happened to be on linsoul when they went up at $20 briefly.
So there was a BL-01 prior to these?
I wonder if I'd be even more controversial than them.This cable issue affecting sound is highly controversial. Seen flame wars start on the audio forums about it.
Basically there's 2 camps. One believes it changes sound subjectively, the other says it is placebo and there's no measurable changes. Well to each their own, i respect both sides. If u believe in cables, good, there's another area to play with to get audio nirvana. If u don't believe, also good, u save a lot of money in this hobby.
FWIW, i do believe in slight sonic changes in cables, but mostly in high sensitivity type multi driver iems. Cause maybe they add impendance to the chain and for these high sensitivity types even a small added resistance may skew the FR? Whatever the case, don't spend too much on cables, definitely don't let it cost more than the iem and u get more sonic changes with eartips or source changes (cables i find are very subtle changes at best).
Explore for yourself and see if u find changes. Most cable believer campers say pure copper cables increase warmth and bass, silver plates ones increase clarity and upper frequencies. YMMV.
Is it called the BL-T3 now? Actually, wait, i don't care. I need a chi fi break and definitely don't need any more buds that hurt my ears.
You must be the one with the most blon iems! Have you tried their S1 model?It isn't called the Blon BL-T3 or BT3 now, although they share a casing and are priced the same. The impedance of the two units is different and the tuning is slightly more V Shaped on the BT3 (the OG BL-01 was a very neutral tuned thing, much like a low-rent Tin T2). Neither of them are the same as the NICEHCK EP10 which also shares the casing. The BT3 is very good, the original BL-01 is amazing.
Having posted a couple of pages back a photo of my BL-01, BT3, BL-03 and BL-05 I am pleased to announce I have just received a BL-05S and just ordered a BL-01 (not the BL-01 you understand, but the BL-01. I already had a BL-01).
https://www.aliexpress.com/item/32788409774.html
Well, then I have good news for you. Skip the B20, its bad.Oh stop it you! I've not tried the S1 or the Cardinal/Bluejay (or the B7 or B20 cans - the B20 appeals...) Yet.
I do love me a Blon and get a new pair at every opporty. As I type this I am listening to the BL05S - hot dang these are good at Metal.
BL03 is so good that i think it deserves a thread, also rumors that improved model in the future exist so lets keep the ball rolling.
I think they're trying to win a bet that hype can overcome basically any level of stupidity.I see... BLON must outsource their marketing department to the Marx Brothers
