F700
Your ears will tellI was ready to buy Kbear Diamond but when i saw blon 05 i say What... I hope it's a good choice
Right! it was good if I listened to Diamond to hear the difference. I trust the blon
I hope you will be satisfied. The wait begins, as always.Right! it was good if I listened to Diamond to hear the difference. I trust the blon
I just got a replacement pair of BL03s. As much as I liked my 1st pair, this pair sounds even better, with more air and spaciousness. The tuning is soooo intoxicating. I just hope they continue to work. I still don’t know what happened to my first pair, and really wish I did, then I could avoid whatever I did to the first pair.
Is driver flex easily distinguishable? I still can’t tell if I’m hearing driver flex, or the crinkling sound from the ear tips.
The good thing is that an airtight seal isn’t critical for these IEMs. I’m using smaller ear tips, to help prevent driver flex, and the sound is still superb.
Thanks! Then the BL03s have a bunch or driver flex compared to all my other DD IEMs. I’ll keep using smaller ear tips with a loose seal then. Hopefully my prior pair failing (actually suddenly just the left side stopped working correctly) was more of a fluke than an expected vulnerability.Crinkling sound is driver flex. It sounds kind of like how some hard candy wrappers crinkle or crunch. Like butterscotch or cinnamon discs or Atomic fire ball wrappers. Some also say it sounds a little like crinkling aluminum foil, but it doesn’t sound quite like that.
The point is that any crinkling or crunching flexing type sound you hear when you insert your earphones is not the eartips, it’s driver flex.
pulling the ear before insertion is the kryptonite of driver flex, it is very easy to do, also the left side stopping to work correctly may be a simple mesh filter clogging, it happens from time to time with metal made earphones with fine tuning filter on the nozzleThanks! Then the BL03s have a bunch or driver flex compared to all my other DD IEMs. I’ll keep using smaller ear tips with a loose seal then. Hopefully my prior pair failing (actually suddenly just the left side stopped working correctly) was more of a fluke than an expected vulnerability.
FYI, I took a careful look at my Blon Cardinals and the Cardinal driver appears to be the same one that was posted as the BL05 driver.
That probably explains why the Cardinal does sound slightly different than the BL03. Especially the sub bass extension. Obviously, the shell difference affects that also, but it was always assumed that the BL03 and Cardinal share the same driver because they were both listed as 10mm carbon nanotube. But now that seems to not be the case, with the Cardinal‘s driver being a 2nd generation design.
Hmm but the Cardinal came out about 6 months prior to the BLON BL-03. Unless they were using older CNT drivers for the "newer" BLON BL-03? Though 6 months in this CHIFI industry is considered a long time, and much technology can develop just within a matter of weeks (cough cough -> NiceHCK NX7 to NX7 Pro).
Even within the Cardinal lineup, there are some sets with an attached spaceship like nozzle filter, and some that come without it. Not sure how this filter thing affects the FR of the Cardinal, but it probably does.
I thought the mids of the Cardinal vs BLON BL-03 were pretty similar, with some slight differences in the treble, but agreed the subbass is better in extension on the Cardinal. Though I've always attributed this better subbass due to the better isolation, fit and soundstage of the Cardinal.
