Blon in ear monitors impressions thread
- Thread starter FastAndClean
In this thread we post pictures of the Blon 03 with new cables, the sound has become overrated. Give me new cables
What about pictures whit stock cable ?
jetzt reichts aber
Nein niemalsjetzt reichts aber
originalsnuffy
My wife tells me I am over-rated. Maybe I need new cables.
Well, you have two options; either cheat on her with new cables or suffice her with your clean already great cable.My wife tells me I am over-rated. Maybe I need new cables.
thefallenangelx
Anyone willing to share their EQ for these Blon Bl-03?
Thanks
Thanks
ScrofulousBinturong
After about a dozen different eartips, I have found a set that works for me.
Seller: DD-Digital Store
Item: 1Pair Soft Memory Foam Earbuds Earmuffs T100/T200/T300/T400 S/M/L Sizes Noise Isolation Eartips for In-Ear Earphone Accessories
Size: T400 Large (for me anyway).
I have a mechanical keyboard O-ring at the base and these tips on. They squish down then expand to fill the vast space in my ear. I can shake my head and the BLONs don't fall out. The sub-bass is still terrific (try this song) and the treble is still there. Crash cymbals are a little recessed but that's just as well for me.
Behold:
https://www.aliexpress.com/item/4000018660185.html
Behold:
originalsnuffy
Thanks
Yes. Set all bands to the mid point. Also known as zero. Best bet is to just turn EQ off and enjoy.
That is the hallmark of a good IEM by the way.
kukkurovaca
- Apr 7, 2017
Thanks
Is there anything in particular you're looking to correct or improve? I know some folks would prefer less midbass, for example.
If it's a case of something bothering you that you can't quite put your finger on, sometimes it's a helpful exercise to start by comparing to another IEM that you particulrly like the tuning of, and try to EQ closer to that frequency response. Crinacle's graph tool has a neat "baseline" feature that is particularly handy for this.
Here's an example, showing how the BL03 differs from the iSine 20:
If you go back through the thread ive posted a coupleAnyone willing to share their EQ for these Blon Bl-03?
Thanks
Hi guys, I just received my Blon... but.. I ordered brown, correct me if I'm wrong, but this looks pretty silver-like to me. I received a softish velvety beige-grey bag with BLON 2014 written, 3 extra pairs of useless grey eartips, and one small spinfit-like pair that was initially on them, and one mid size pair (fits best for me), but still everything fits terrible..( Didn't get any black tips, does that mean I got a newer version? The cable's definitely not great, but I guess it's ok, waiting for new ones. They sound good, but not nearly as good as I was expecting Will burn in help? When I look at the metal vent (that's what it's called, right?) I can see 2 dots of soldering(?) (2 small dots that look like copper), is that normal?
Sebastiaan156
So i bought these and did not expect much of Them as they are hyped as screw.
Got Them today with a **** 16 core copper/silver cable. Hooked Them up and found that it was near impossible to get a good seal, normaly unisex mid silicone work for me but these Just didn't seal. Now use the largest set silicone i have and they seal.
I have not found a pair of foams that works for me with these.
They are really small and block less noise than other iem's i own. They also require more power/volume compared to my OH1 or ie80s
Pluged Them in my fiio M5 and starter playing music, now i get the hype!!!! This is what i desired from the ie80s (senheisser shame on you!!)
They are really good, and if you factor in the price they are heavenly wicked sick!!!
dharmasteve
Welcome to the Blon 03 club. Lousy tips, basic cable. My second pair had that little bag and 2014 written. You have to work to get the best sound. I replaced the cable, fitted a home made spacer and added JVC Spiral Dots and reckon they are as good as any IEMs I've had. Yep they do improve with burn in.
