Hello there, I dont write here too much, only to give my impressions.
So I've acquired the BLON'03 and have been using them for the past three days, and how do I begin this?
The hype is real with these IEMs. I have acquired the following sets: FH5, FA1, HD600 headphones, Momentum 2.0 wireless headphone, and Koss . I'm considering the BLON'03 to be the best among them in regards to price ratio = performance , even better than the Koss KPH30i in that regard imho.
First thing I did was to swap out the cable for a TRIPOWIN C8, and tips for a Spin Fits CP-1000 medium size. I was not going to bother with the stock cables and stocks tips cause I wanted the best impressions out of them after unboxing.
COMFORT & FIT:
So, after swapping the cables and tips, I haven't had any problem with the fit at all. I can use them for hours and I experience basically no fatiguing while wearing them on. Although, due to its respective design, I think they do not seal enough as let's say my FA1, so the isolation is on the average side; however, I haven't felt the need to adjust the seal on my ears cause they sit right and do not fall off my ears, not even while I'm in movement.
Personally, I had a way more annoying situation with the fit on my FH5 due to its short nozzle and bulkier design compared to my BLON'03. To the point where I had to mod them out.
SOUND IMPRESSIONS:
God damn, almost everyone here has already said these perform way above their price, but I was not expecting such performance in practice; it's way better than I expected.
All these sound impressions are done while having them paired with my OPPO HA2SE for reference
So with my rookie manner to describe the sound signature out of these IEMs. They actually give you a sense like if they were V Shaped type of signature, but they actually are not! All the details given by every range are there in some way.
BLON'03 has a balance sound signature with a bit of mid bass boost but I consider these IEMs as the BEST example of "BASS NO MIDDLING OR BLEEDING THE MIDS AND HIGH RANGE".
Hell, even when I compare them to my FH5, which the later has a more sub bass focus, you clearly notice how the bass somehow bleeds the the mids a bit on those sets; but!! the BLON'03 bass, while poweful, it gives you a sense like there is layer or a wall that is separating the bass against other frequencies allowing you to pin point each range clearly. Though this does not mean the set does not provide you with that low mid range humming on certains instruments such as guitars, etc. When the track demands it, of course. The tonality and timbre on this set is perfect and so pleasant to listen to.
I can understand some users may think the set has too much bass for them, but hell, it is fun bass to listen to, and I think this set does not need EQ in any way. Although you are free to EQ it if you wish to reduce the bass a bit.
The Mids and highs are clear and detailed, though the only negative I would put on them is the vocals may sound a bit on the thin side.
Vocals are not forward. However, they give you a sense they peform a bit above you or above instruments though on the thin side, and I would say I miss a bit of volume on them( yep, I got very accustomed to the intense shouty vocals performance of the FH5, and that high volume vocals of my HD600)
Treble does not wao me ( I'm coming from the HD600 which has an spectacular treble) though they were well extended, sweet and non-fatiguing
Soundstage is decent, wider than my FH5 for example, but instruments separation is on average side. Here, you can clearly realize the advantage when it comes to instruments separation or imagining in favor of my FH5 due to more technicalities, thanks to having three Balanced Armatures on them.
Overall, an amazing purchase!! It's too good that I'm now ordering my second pair through Amazon as a back up.
