tutetibiimperes
Found a frequency reponse graph for these on taobao
Thanks! I wonder if that's raw or compensated, should one be able to just 'fill in the gaps' with an EQ profile? I'll have to play around with it. The upper midrange suckout jibes with what I'm hearing. So it looks like it'll need 8 or so db of boost around 1.6ish khz with a little less boost centered around 2/2.5khz and maybe a bit of a mid-treble boost, though that 5/6khz range can sound harsh if taken too high.
So what I'm getting is the fit isn't great and the sound is just ok...?
Stock tuning leaves a lot to be desired, but they seem to take to EQ very well. I wouldn't buy them if you don't plan on EQing, they're no HD650s that are 'right' straight out of the box, but they feel like they have a lot of potential once dialed in.
Fit is the major issue, though I'm hoping we can figure out a headband solution for these.
