tamu
- Nov 6, 2008
I cant remember the website but there was a company in states that would accept your parcels and forward it to you.. Very usefull in such times indeed..
thanks , but he does not ship to UK.
Hey guys, so I'm looking to fill in my bijou with some good caps. I have been looking at those oil run caps, but I just have one question. if i parallel to say 300uf, I get a corner frequency of about 8.5 hz with my 62 ohm k701. Do you think 300uf value will be adequate for lower end response? I know you're not supposed to hear 8.5 hz but that's -3db corner freq, I am just wondering if I will be missing any lower end by not using a higher value. Btw I intend to use my 62ohm k701 and my 600ohm dt990s with this amp. almost done buying all the parts for this baby..boutique caps are expensive!!
well I was hoping to be able to omit C6 bypass cap, but I would probably have to buy one if I used electros for c5. I am looking to spend my $ on film caps for c5, was just wondering if 300uf would cut it for my headphones. I think I'll go ahead and order the oils runs for now as 13 dollars a pop is fairly cheap for 100uf.
also can someone please clarify ampheads ps mod? Should I go ahead and just do it even though I'm starting from scratch? am kind of undecided if I should do this mod, as I intend to do regal, choke ps ,and no nfb. Would amphead's mod be of any benefit?
