fishski13
Member of the Trade: SolderWorksAudio
- Nov 2, 2004
finally soldered in the M-caps, but now getting loud ground hum and tube microphonics in both channels. ohmed all the wiring out - measured fine, even the board mount Phoenix screw-connectors to J1. the attenuator measures fine as well with the input jacks. i even ohmed out the interconnects. my Bijou was working fine before inserting the M-caps. in addition to the caps, here's what i also did:
-shortened and re-routed heater wiring.
-sheilded B+ wire with screen grounded via red wire next to star ground since it is running over the heater wiring.
-re-routed grounding wire; the R channel grounds run underneath the L channel board.
-moved star-ground closer the PS board.
my unsheilded signal wiring isn't perfect as i am going to try some Cardas and silver wire as well, but could this also be the problem? ground wires under the boards? btw, my R channel input wire off the attenuator is green, the L channel is red.
i'm glad i waited to tie in a bunch of cable ties to neaten-up/secure the wiring.
what am i missing here?
