Beyerdynamic to launch new top headphone at IFA -- called T1
Feb 26, 2010 at 3:30 AM Post #2,146 of 3,971
Originally Posted by musicman59 /img/forum/go_quote.gif
I have not listen to them enough yet to make a fair comparison but out of the box looks like the soundstage is smaller than the HD800 and the sound more in your face especially voices. Regarding the bass I would say is as good as my HD800 with the DHC Complement copper cable.
Out of the box, the T1 didn't have much bass but it improved a lot after 3 hours of burn-in. After about 30 hours of burn-in, the T1's bass blows away the HD800. IMO, its not close enough for cables to make a difference.
Feb 26, 2010 at 3:36 AM Post #2,147 of 3,971
I thought somebody here said that the cable actually had 3 wires were the negative and the ground (the one attached to the back of the driver structure) were connected together to the ground of the TRS plug.
Did I misunderstand something?
Have anybody re-termiate the T1 stock cable to balanced yet? or at least took a look to it and confirm what I am seeing? (1 wire and heavy copper shielding per side)
https://www.facebook.com/MoonAudio/ https://twitter.com/MoonAudio https://instagram.com/moonaudio https://www.moon-audio.com/ https://www.youtube.com/@moon-audio sales@moon-audio.com
Feb 26, 2010 at 3:38 AM Post #2,148 of 3,971
Originally Posted by MacedonianHero /img/forum/go_quote.gif
I absolutely agree with Skylab's assessment. And for me, this is the best presentation of bass I've ever heard. Deep, controlled with detail and just the right amount of impact.
Stop it, you're killing me!!!!!!!!!!!!!!!!!
Feb 26, 2010 at 3:39 AM Post #2,149 of 3,971
I did notice a difference in my HD800 bass with the Complement cable and balanced configuration. It did get deeper, more control and impact.
It will be interesting to compare them after the T1 has 200 hours of burn-in.
Feb 26, 2010 at 3:42 AM Post #2,150 of 3,971
Originally Posted by anetode /img/forum/go_quote.gif
My pair finally arrived today. So far I'm liking the T1s ability to subdue sibilant recordings without any noticeable sacrifice of treble detail.
For me this is where the magic is. It's hard to find a headphone or speaker that pulls this off well. I've personally found there is a fairly narrow frequency band in the upper midrange and low treble that greatly affects this quality. Some headphones deliberately notch this frequency out with a significant dip in response, and while some may frown on this as not being a neutral response I've always found the result to be to my liking without giving the impression of a lack of balance.
Feb 26, 2010 at 3:43 AM Post #2,151 of 3,971
I didn't need a cable upgrade (and balanced) to find that the HD800s bass quality (control and detail) still slightly exceeds the T1s. The T1s are more impactful and generally I prefer their bass presentation overall.
Feb 26, 2010 at 4:01 AM Post #2,152 of 3,971
One thing I noticed is that the T1 are harder to drive than any other headphones in my collection. In my RP010B I need to go around 11 o'clock even using the Hi gain output and with the GS-1 needs just past 12 o'clock in Hi gain too.
The rest of my headphones the amplifiers are between 9 and 10 o'clock or even less.
I just finished setting things up to start the burn-in process 24/7 for 8 days.
Feb 26, 2010 at 4:05 AM Post #2,153 of 3,971
I agree with you MacedonianHero, the HD800 with the stock cable sounds great. I really liked them. What I am saying is that the Complement cable IMO took them even to a higher level.
Feb 26, 2010 at 4:31 AM Post #2,154 of 3,971
You need to get yourself a tube amp.
Feb 26, 2010 at 6:59 AM Post #2,155 of 3,971
Yes, same spot...my number is "1123". I got mine about 5 weeks ago and if you just got yours that makes only 179 built in that period. That would be an approximate production capacity of 150 per month.
Wow, that's not a whole lot. But for $1000 headphones, maybe it is?
Mine is 1404 and I got mine 2 weeks ago. That's 281 in 3 weeks, about 100 per week.
Feb 26, 2010 at 7:24 AM Post #2,156 of 3,971
are the T1 considered as hard to drive? is it like the senns (HD600/650/800)
or less than that? I read that the beyer technology increases their output volume to twice the volume or something like that.
Feb 26, 2010 at 7:48 AM Post #2,157 of 3,971
I would also like to know what improvements anyone heard going from SE to balanced.
Feb 26, 2010 at 9:08 AM Post #2,158 of 3,971
Yes. They are hard to drive like high-end sennheisers. You are not getting enough volume direclty from ipod, for example.
Feb 26, 2010 at 11:30 AM Post #2,159 of 3,971
T1 stock cable has 3 wires per each side.
Red(or green) and white inside, black shielding outside.
And all 4 wires except red and green were soldered together to the ground of the TRS plug.
