Tuneslover
I have the DT1350 that I use primarily for portable use. They sound awesome and was wondering how the DT770 250 ohm sound in comparison.
DT770 bass isn't as tight and overabundant, and midrange/treble balance isn't as good as DT1350's.
On the other hand, DT770 is more resolving, transparent to the source, and has a bigger soundstage. DT1350 may give an impression of "listening to music through a keyhole", as my friend put it, hahaha.
Do post what you think of the closed-back 598 versus 1350 and DT770, if you don't mind.
I get your friends "keyhole" description...LOL! Sounds as though you're saying the DT1350 is an overall better sounding headphone than the DT770, which comes as no surprise to me.
I just ordered the 770's on Amazon this morning and I also have the Sennheiser HD598 CS (closed back) coming. I'll compare both sets of closed cans and decide which one to keep. I also have the HD598SE (open back) which I like so it will be an interesting comparison.
Thanks for the feedback.
Thanks!
Yeah, what you observed with DT770 is that it tends to need more output power, especially the 250-ohm version. HD598 and its brothers are far more efficient, no upgrade in amping necessary as you noticed. Schiit probably has a decent budget amp that can show you what DT770 can really do, or a Matrix M-Stage is another good choice if you decide to try it out again later or one of the other 250-ohm Beyers.
Sennheisers tend to have a more relaxed and organic sound, with few exceptions.
You probably won't like the other closed-back headphones around as much as that 598CS, not even HD380.
Looking at his profile, he seems to have some fine amps including the Jotunheim and the Lake People G109-S
