FND_UA
HPC-22WWhich cable in particular?
Thanks for the info @L0rdGwyn, I did get a cable from ebay a few weeks ago but wasn't overly impressed, it did affect the sound but not in a good way, as is usually the way, you get what you pay for!, think I'll have to do some more research, once again thanks for your input!.So, did a bunch of side-by-side listening between the stock uncoiled cable and my Black Dragon cable.
My impressions are very much in line with what I experienced with my HD 600 series Black Dragon cable. The custom cable improves the sound-stage and imaging. In particular, it increases the sound-stage and makes the image wider, more enveloping. Also gives the impression of increased resolution.
Obviously this isn't any kind of double-blind test, but I tried my best to avoid confirmation bias. Once I noticed the difference in one track, I specifically focused on that aspect of the sound and listened to tracks that would display the differences best. Switched back and for no fewer than ten times, minimizing the amount of time between in switch (got it down to probably 5-6 seconds).
I didn't used to believe in cables making a difference in sound, until I made the Black Dragon for my Senn's and did the same comparison with their stock cable, then I became a believer
They're pretty dissimilar. HexV2 is fairly laid back, really easy going. DT1990 is an all-rounder with a slight sparkle at the top. I personally didn't like it as much as it sounded a bit unnatural, thought most of what I listen to (classical, jazz) isn't really its strong suit. Also take into consideration that a planar will sound inherently different to a dynamicHey anyone here have any experience with the hifiman edition x v2? I have a chance to get either at a decent price from their rrp and im lost as to which one to choose i own the dt990 250ohm and use them with a centrance hifim8. I eq down the treble and turn up the bass. I find the dt990 mids a tad far away but for electronic music like vaporwave and stuff they sound amazing!! Hope yoy guys can help
Ahmm I tried both in Canjam SG with both same tracks and what is noticeable is the lively treble of the 1990s. Sundara for their price is good. Not bassy but just decent amount, proper mids that is not shouty nor too forward and treble that isnt piercing. Makes me wonder how other Hifiman models can be too much more expensive eventhough this sounds quite as good as those albeit the design which Im not really a fan of (esp that black chicken mesh/wire). There was even a guy who told me that Sundaras sound better than what I was auditioning - the LCD2Cs which was a spoiler haha. Meanwhile the built on the dt1990s looks quite good. Its just that when I listened, with pads Im not sure which (analytical or balanced), the sounstage was small, everything was quite on your ear with the treble being very noticeable. Nevertheless, they sound good but they seem to be really for monitoring, so if you want a bit more relaxed just for enjoying music, and have the option to go balanced, then Sundara it is! Try both if you have the chance. Cheers!Someone has compared the sound of the 1990 dt with the sundara?
I bought the dt 1990s as an upgrade from my dt 880 pros. The sound stage and detail is a huge leap compared to the 880s. But the treble can get really harsh at times, much harsher than my dt 880s. My dt 880s were driven by a home theater receiver (Yamaha HTR 6230. I know I know, it's pretty amateur but I'm currently in the process of building up my gear) powering the headphones and am wondering if the treble can be a bit more controlled with a proper dedicated amp? Any suggestions on a warm amp that's under $400? I mainly listen to classical music.
Asthmatic is the perfect word to describe the 1990s when I lowered the 8 khz frequencies -3db or so using the built in receiver EQ. The 1990 lost its sound stage (also if anyone is wondering about how the DT 880's sound stage compares to the DT 1990, the perfect word is, you guessed it, asthmatic.The DT 1990's presentation is THAT good). So the Topping A30 eh? I'll take a look. Where did you buy those?I noticed the same thing. Before getting a new amp, I tried several things. First, I tried new earpads, what ended up working for me were the Brainwavz round velour earpads after I cut out the mesh inside. Then I used Electri-Q, to dial down the frequency peaks according to the frequency response graph I found at DIY-Audio-Heaven. I also bumped up the low end a tad and then used a fixed gain setting to bring everything down a bit. What I ended up with was this:
Tamed the highs, without losing clarity. After this I noticed that my headphones were sounding somewhat...asthmatic. The Fiio K5 just wasn't giving them enough power. I pored over several amps and narrowed my decision down to the Aune X1S and the A30-D30 topping stack. I only managed to audition the Topping stack and I got the A30 right away, I left the D30 for later. The A30 gives all that extra mph the DT-1990 were calling for, the D30 brought back the harsh treble, but amazing deep rich low end, since I was feeding the audio from the coax out of my Fiio X3-II and the time I had with the thing was short, I didn't play with the EQ settings so I didn't bring the D30 home.
TLR, try the topping A30, wonderful little thing.
