pietcux
The frequencies just above upper sub-bass.
Bass is 60 to 300 Hz. Male voice starts at 100 Hz. Cello and some other acoustical instruments start at 60 Hz. Go figure.
I'm detecting a bit of underestimation of modern phones... especially Apple.
At RMAF as one of my test tracks that I used for audition the DT1770 was Aaron Copland Fanfare for the Common Man a very short piece with brass and percussion.
Four horns
Three trumpets
Three trombones
Tam-tam
Tuba
Timpani
and Bass drum
I heard this piece performed live and you can feel the bass. The longer version with orchestra was Aaron Copland third symphony, last movement. I heard that in Boulder Colorado live as well. Very inspiring piece of music good for testing gear. Using the DT1770 leatherette pads the bass has much sharper attack than the velour pads, very obvious difference. For testing of dynamic range I sometimes use Mahler 8 there is short example on YouTube.
https://www.youtube.com/watch?v=nrH9Kh2vOpo
I also use solo pieces as well.
For the rest of the readers: I am back on track.
Welcome back hanselmann.
I have to tell you that I love my DT 1770 PRO very much.
And can we cast you questions about this headphone as we did a month before?
Sure, anybody can ask questions as before. I was off a bit, since I was on holidays and IFA trade show.
Great, then My questions are:
1. Will DT1770PRO's earpads (these are very high quality!) velour or P leather, be available as replacement parts? if yes, can you say when?
2. Can I use Mini-XLR cables for AKG 240/702 in the aftermarket for DT1770PRO?
3. I think you will refuse to answer this questionbut, Do you guys have a plan for open back version of DT1770?
Thanks in advance.
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
Pietcux, can you share some impression from DT1770 vs MDR-Z7, please? I want both but can't choose which one to get first.
