Beyerdynamic DT-1770: Product Info, Discussion and Impressions
Feb 23, 2016 at 2:02 PM Post #1,741 of 3,701
If only T5p.2 has more bass and less energy on the high, it would be perfect.
Yup, I ab the 1770 and t5p.2 at canjam, walked away with the 1770. The T5p.2 had the typical beyer sound, thin and trebly
My impression is far from that. The old T5p -- yes. The new one: definitely neither thin nor overly treble-happy. Yes, the DT1770 is warmer, but the new T5p is nothing like the original model. Except the looks...
Feb 23, 2016 at 2:23 PM Post #1,742 of 3,701
If I find the time I will take some pics later, I just came home from work. It's around 7 pm here.
Here you go. Do this on both ends and then you can shift the cushion to center it.
so it doesnt just break out into a million pieces after removing the two screws, thats wonderful news. I will be able to handle that in a few minutes time then.
Feb 23, 2016 at 2:33 PM Post #1,743 of 3,701
Thanks @pietcux for taking the photos. Opening that part is no problem and easier than sending them back for sure. If the headband itself is defective it another thing of course... but I suspect it just slipped out.
Feb 24, 2016 at 8:19 AM Post #1,744 of 3,701
took a few minutes but my headphones will no longer be of issue and got in early enough to work to get a few moments to relax with them before I have to dive into my workload.
Feb 24, 2016 at 9:23 AM Post #1,745 of 3,701
I knew you could make it!
Cheers
Peter
Feb 24, 2016 at 9:11 PM Post #1,746 of 3,701
I saw somewhere in this thread (can't find the post) that the EDT 600 SS pads were recommended as possible replacements. I found out that they don't work. They're too small to fit around the lip. They aren't too much different from stock either. They have a very slightly different feel and are a little firmer though. I don't want someone to make the same mistake I did.
Feb 25, 2016 at 1:30 AM Post #1,747 of 3,701
Thanks for the warning. Beyer offers so many pads themselves. All pads for DT770,880,990,T70,T90,T70p,T1 and T5p will fit.
Feb 25, 2016 at 8:28 AM Post #1,749 of 3,701
Does anyone know where I can order that new case for the T5P? Hoping the 1770s fit in it.
I have no idea but report back if you find it fits or does not fit.
Feb 25, 2016 at 2:07 PM Post #1,750 of 3,701
Don't know, haven't even seen the case...
But this one has been mentioned previously, and the one I want (is this the one you referring to?):
http://europe.beyerdynamic.com/shop/dt-hard-case.html
http://www.ebay.com/itm/Beyerdynamic-DT-Hard-Case-/181889998187?hash=item2a597d1d6b:g:UJgAAOSw37tWDVGW
Feb 25, 2016 at 5:00 PM Post #1,752 of 3,701
Feb 25, 2016 at 5:20 PM Post #1,753 of 3,701
http://europe.beyerdynamic.com/shop/hah/accessories/dt-hard-case.html
DT Hard Case
€24.90
Article Number: 718971
Delivery time: 3-4 days
Sturdy hard carry case for circumaural headphone.
Fits DT 1770 too. More compact than stock case they came with.
Feb 25, 2016 at 5:25 PM Post #1,754 of 3,701
Why, because of the different cable routing?
No, the headband seems to be a bit thicker and the case is too shallow there. The gimbals seem to collide a bit as well. I can try to tak a photo tomorrow.
DT Hard Case
€24.90
I have one of those as well but did not try it with the DT1770 so far. Good to hear they fit in.
Feb 25, 2016 at 5:36 PM Post #1,755 of 3,701
Could you try? I heard on thus threaf they fit. About to order but will wait for your response.
