A little update on my sich. I returned the white AT M50x. And thinking about getting a pair of the black ones instead, because the pads seem a bit more pliable on those. One vendor said the pads on the white version are thicker and stiffer because they have a different kind of pleather or coating than the black ones. I'm not sure if that's true. But the pads on most of the black M50x's I've tried seem a little thinner and a little better fitting than the white pads, which really didn't work for me at all. Plus, I just like the black better, in part because it doesn't show the dirt as much.
If I get the black AT M50x, then I may make a thin cloth covering for the earcups to try to make them a bit more comfortable. That has worked ok with other HPs I've owned. Certain types of cloth can attract static electricity though, which is not a good combination with a headphone that has sensitive wiring within. I may also try some aftermarket pads, or just making my own.
I ordered a new pair of the 250 ohm Beyer DT-770 to replace the used pair I currently have. If I can get the store that I bought the used set from to drop their price significantly, then I might keep the used pair instead of, or in addition to the new pair. These are still pretty hard to find though, so I doubt they will discount them any more.
I spoke to Pete at Beyerdynamic again as well, and he said they were expecting another shipment of the 250-ohm DT-770's this week in the North American distribution center. So some retailors (such as Sweetwater) may be getting more Beyers in stock fairly soon.
I will be returning the 80-ohm version of the DT-770. The 250-ohm just seems to be closer to the kind of sound I'm lookin for. Still lookin at a couple other potential options as well, like the AKG K371. And at some different methods for driving the headphones.
I also did do another listening session at GC recently, which included the AT M40x and M50x, AKG K371, and Senn 280 Pro. I think the 250-ohm DT-770, with some EQ-ing to tweak the treble and bass and L/R balance, is still my favorite of the lot. With the M50x probably still in the runner-up position. I like the sound of the M40x and AKG K371 as well though. The M40x seemed a little too rolled off in the sub-bass. (Though that could probably be ameliorated with an EQ). And seemed a bit less comfortable than the M50x. Though none of the ATH HPs is really that comfortable for me it seems. And I still intensely dislike the hinges and headband extenders on the AKG K371.
I think the only open-back I'm considering at this point is the Beyer DT-990 250-ohm. Though I still have some interest in a couple other models, such as the Senn 58x, and maybe the AT R70x (which is currently a bit more than $250). I like good bass extension though, so open HPs are somewhat lower on my list of priorities than closed-backs right now. I'd like to give one or two of these a try though, at some point, because the open-backs have a different sound.
I also wish I could find a nice flat, reliable, solid-state headphone amp, with balanced (+4 dBu) and unbalanced (-10 dBV) inputs, and switchable impedance for around $100-150. That would make things a bit easier in my setup. I visited a smaller audio shop near me that caters to more expensive audiophile listeners, but they didn't really have anything for less than around $500. And only carried Grado, B&W and Audeze HPs... None of which interest me at the moment. Amps are probably a topic for a different discussion though. And I'm still not sure I have the bread for a separate headamp at this point.
I also returned the DBX graphic EQ, for now.
Still also not a big fan of the fixed coiled cable on the 250-ohm DT-770. Though so far it has only been a minor distraction.
