1clearhead
- Apr 5, 2013
....will check it out, thanks!Check the review on audiobudget.com
Yea, I just checked the reviews on the NarMoo B2M and it looks like they might not be neutral, or at least, coming from the same housing. ...Thanks for your reply!They're fine. Pretty much just a rebranded NarMoo B2M.
I have the QKZ W3 Pro which also has the DC connection. I'm also surprised it hasn't been more widely adopted. The W3 has a 9.2 mm driver. I'm curious as to how it compares to the W1. The W3 is a total steal for the price and may be in my top 5 for sound quality.Fonge W1 Pro is the same as the QKZ W1 Pro (probably sold under different names on Aliexpress in addition to Fonge).
It's a single 10mm dynamic driver in a transparent housing.
I haven't listened to them in a while, but from what I remember the sound was fairly neutral. It's not super detailed or resolving, but is enjoyable to listen to.
For its cost ($5-$6) it's a great value, and an easy IEM shell for driver swaps. I own 2 pair (1 stock, 1 modded). It also responds well to mods - 2-3 holes of 2mm each drilled into the rear cover really opens up the sound.
- Average build quality and cable for the price
- worn behind the ear, very comfortable fit
- removable cable with "DC-style" plug
- totally sealed (so it is sweat proof and excellent for working out)
- sits quite flat in the ear, so works for sleeping
I wish the DC-style plug was used on more IEMs - it's easy to plug and unplug, reliable, robust, and impossible to plug in out of phase.
hi guys, I need advice, I'm about to buy the kz-zs6 + silver cable and rubber. According to you on the € 50 you can have better? I do not like too many basses, a balanced sound but also a bit 'fun (space between various musical genres).
yes, you're right, but it depends on the traces I'm listening to. I do not always like natural sound. it is hard to explain. So you would not take the zs6?Balanced and <€50 = Tinaudio T2.
But fun is like the opposite of balanced.
I agree...and would not recommend the ZS6 at all: great looks, piercing treble...chainsaw! Reviewers recommend the much cheaper ZS5, but version 2 also has the horror treble added. The T2 is a much better sounding earphone, so are the Brainwavz B100. Adding the "fun" part, the B100 should probably be considered.Balanced and <€50 = Tinaudio T2.
Thanks for the advice, the Brainwavz B100 can take them instead the T2 are not sold here Italy. Brainwavz B100 are lower.I agree...and would not recommend the ZS6 at all: great looks, piercing treble...chainsaw! Reviewers recommend the much cheaper ZS5, but version 2 also has the horror treble added. The T2 is a much better sounding earphone, so are the Brainwavz B100. Adding the "fun" part, the B100 should probably be considered.
T2 has a treble spike too, its weakest point IMO, not sure why it doesn't get mentioned.
