groucho69
Sadly that deal has long since passed..
I like the T2 so much that I wish I had bought 2 at that price.
Sad? No, TRAGIC!
Sorry to pester you, but any news on the T2 deal? Thanks for everythingYEAH! Portapro WIN WIN WIN!!! Hehe!
Weren't you suggestion the K403??? Quite not elogious what your friend heard from them....ah, subjectivity of hearing!
Urbanfun being boomy...first time I heard this description about them.
I compare ultra fastly ZS5 V1 and V2....and V2 was having bacground hissing wich V1 do not have with track I was listen....treble is very hardcore with V2. I'm confuse, did you confirm by checking inside nozzle if you really have V1? I confirm too that KZ silver plated cable improve sound and clarity, bass became more controlled as well ( was obligate to use stock cable to compare the 2....and difference isnt placebo!!!!!!!!!)
EDIT: What the heck. Cable change drastically everything...and all my impressions came with this cable, this is why when I listen V1 with stock cable I was doubting my hearding, like...how can have I accepted this type of muffled boomy bass....? This-is-not-suppose-to-sound-crap. ZS5 focking RULES!!!!!!!!!!
Hum...as said, im kind of a nobody for Jim...so, unfortunately he did not answer me yet and now I just write a last message...before getting kind of insulted by lack of answer! Wish gearbest sell Tinaudio T2, this way, for sure it will have more deals possible.Sorry to pester you, but any news on the T2 deal? Thanks for everything
I'm not a big believer in cables, but I have experienced differences in cables which I believe boiled down to impedance differences:
- I used an AUX extension cable for watching moves in the past, and it had a horrible effect on the sound. I discovered the impedance was ridiculously high, but I never figured out if it was the gauge of the cable, or if it was copper clad aluminum, or what. I just threw it away and got a different cable (with no degradation in sound).
- I've recabled IEMs before (that had cable failure) with "new" DIY IEM cables bought from Aliexpress (ie probably removed from defective IEMs). In a few cases, there was a noticeable change in sound for the worse. Some of the cables I used looked like KZ IEM cables (and never had a problem), but the ones in question looked kinda like the whitish ones from MEMT X5 (but they were of unknown construction and origin). The impedance was again very high. Changing out the cable a 2nd time with a KZ IEM cable solved the issue.
- The stock cable that comes with the KZ ZS3 and ZS5 is very meh in my opinion. I don't remember if it's the mic or non-mic version, but a number of members have measured it as having higher impedance than the KZ "upgrade" cables (you'd have to search, but pretty sure it's something like 3+ohms). I don't know if it's the silver plating or not, but on the ZS5 v1 I did hear a very small difference with the stock cable vs the upgrade cable.
But my take is that if the stock cable is of 'high quality' to begin with (ie good conductors, good connectors, adequate gauge, lowest impedance possible, etc), then upgrading the cable isn't going to make any difference in SOUND (despite making a difference in microphonics, looks, reliability, better balance due to microphone deletion, etc).
I know cables are a polarizing topic, but I'm just providing a few cases where they HAVE made a difference in my experience.
Awesome! Thanks so much for replying to this..
So then, would you say the B100 is above the T2 or vice versa?
And a Happy New Year to you as well!
Hmmm, probably my only "micro-complaint" about the T2 is that I wish it was a little bit clearer..I'd say they're complimentary. Want a warmer sound with a more impact low end? T2. Want more detail and clarity? B100.
Get the B100, you apparently don't gain anything with the B150. If you want a detachable cable, get the B200, which is said to sound like the B100 but with more detail.The B150 is ONLY $55.60 on Brainwavz page:
https://www.brainwavzaudio.com/products/b150-balanced-armature-in-ear-earphone
Use the promo code "HEADFI" at check out and it drops to only: $50.04!!
If only the B150 had a detachable cable I would probably jump on it...
I don't know if these will really be any better then my Tin Audio T2???
Is there someone here that has tried the T2 next to the B150 that can talk me into these?
**{B100 is only $35.64 after "headfi" promo code}**
Yes, it is woth owning both. And yes, they are different sounding. An yes, both are rated very highly.Hi Otto Motor, Would you say it's worth purchasing the B100 if I already own (and LOVE) the Tin Audio T2?
The B100 is a great deal right now, but I got a really good deal on the T2 ($36 free ship)..
Are there many differences between the T2 and B100?
Silicon. I don't like foams at all. Size L (13.5 mm).Foams? Silicone? Size?
Which links?@Otto Motor
Those links look like definate scams.
Which links?
