Nimweth
There are graphs on the Phonograph site and on Audio Budget.Show me **** FR graphs... can`t find it atm. Someone posted somwhere in H-Fi but can`t find atm.
Yeah, You`re right. I think I mixed up with some other graph by memory. They are quite "same" at highs but I don`t see how **** is more extended?
Sorry but in my eyes Phonograph is unreliable.There are graphs on the Phonograph site and on Audio Budget.
KP has upper treble energy but is like a peak in the upper treble, more narrowYeah, You`re right. I think I mixed up with some other graph by memory. They are quite "same" at highs but I don`t see how **** is more extended?
They both have littlebit raised lower-highs @ 2-4kHz but **** has less quantity and they both start to roll-off at highs around 5kHz. Anything above 10kHz is off the measuring anyway.
For my personal preferences **** lack sub-bass extension and quantity and 2-5kHz could be tad more raised and even. But this is just my personal taste.
Otherwise **** seems to be very good tuned and judging by graphs could be even better than Tin T3, especially having piezos
Where? Upper-treble is around 7.5kHz-12kHz and there are no peaks, just roll-off from 5kHz down to around 8-9kHz and then fast "rise" into 10-11kHz. And what You mean with "narrow"?KP has upper treble energy but is like a peak in the upper treble, more narrow
upper treble is from 8-9khz and uppUpper-treble is around 7.5kHz-12kHz
Like I said before, anything above 10kHz is usually not so accurate anyway and I haven`t detected any peaks by ears so far. Antroid himself also doesn`t hear it.there
the treble sound like it measures, with a narrow peak in the upper treble, despite your "usually not so accurate" argumentLike I said before, anything above 10kHz is usually not so accurate anyway and I haven`t detected any peaks by ears so far. Antroid himself also doesn`t hear it.
There are not much instruments and notes usually that have a lot of ~12kHz notes. Cymbals/hi-hat are perfect with KP and as much I have listened to music with violins (I don`t listen much classical with violins) and also haven`t detected peaks or something disturbing. Tenor and alto sax have also been delight so far.
YMMV.
over 12khz yes, not your suggestion from 7.5 - 12khz, there is frequencies after 12khz you knowLOL, is there much difference between "starting points 7.5 vs. 8kHz and over 12kHz is anyway usually interpreted as "air".
Pointless arguing imho.
call the sub bass under 50hz "rumble" then, the same logic as "air""air"
