Rainmaker91
- May 27, 2015
I just want a smartphone for the audio..
Actually I only want it to be a smartphone for the internet connection.
I want to stream high quality 1080p audio frequencies from youtube and listen to them with the sony mdr-v6 headphones.
LG V10 still the best option ?
I read some posts, people also refer to the HTC M8/M9/A9 or the Marshall London..
I am in Cambodia there is a shop where they sell the LG V10 for 630 USD http://www.hakse.com.kh/ProductDetail.aspx?ID=1606
On amazon it is usually around 515 USD depending on what type it is..
I know nothing about technology
Thank you
if all you want is a phone for the internet connection, then maybe some of the budget models would make more sense? and if you can stand two units then a cheap phone paired with a dedicated dac/amp would probably give you the best «bang for your buck». Not saying the v10 is a bad choice, but there isn't always a need to get the latest and greatest if your needs dont justify it. Thats just my 2 cents though.
