korzh
- Jun 6, 2016
Please tell us where we can buy that ibasso dc01?
You should have a listen to the WM8741 instead.Is there a modern-ish phone with the sound of the WM8740 DAC? It's my favorite one and since it's not in production anymore was hoping to get something similar in my next phone.
Have a V20 atm and it's not as good as the WM8740 DAC to me.
Thanks! I'll check it out, is it being used in any phones that you are aware of currently?You should have a listen to the WM8741 instead.
where in thailand?I bought from thailand. It released before global launch. I will keep you posted on when it sells global. (Most likely you can order from ibasso.com directly.)
where in thailand?
