nort ycagel
- Jun 4, 2016
Hey guys,
I currently have a Meizu Pro 5 (make that two, but the first one has a fried audio jack), but it slowly becomes unusable. The battery gets worse, it has some charging problems, loses 40% over night even though it's plugged in the whole time, the OS becomes laggy and unresponsive etc. I mean, this thing is nearly 4 years old now, and I already bought it used, so maybe it is the right time to upgrade.
What audiophile smartphone could you guys recommend me? The most important part for me is a big display (not smaller than 6"), maybe a good camera with slow-motion video capabilities, a big battery for long screen-on-times, and of course the audio quality. Budget might be around 300-450€ maximum.
I could get a good deal on a Note 9, and kinda fell in love with this phone. According to https://www.gsmarena.com/samsung_galaxy_note9-review-1805p3.php this might be a nearly perfect phone for audiophiles, but during my quick look-around, I couldn't find anything in this thread about the Note 9, or I didn't look hard enough.
Can you guys recommend the Note 9? Should I wait for the S10 release? Or are there other, better, cheaper alternatives already around?
Thank you very much in advance
If you can get a note 9 for that price then you should do it without too much thinking.
You should really try s9 / note 9 by yourself. They are good enough for low impedance.
V30 / V30+ is a good phone pretty much only SQ wise. Can't recommend it for anything else.
If your pc got a type C port then I suggest to buy the apple type C dongle for 10 eur and try it with your gear. It got quite the incredible measurements and unless you need to drive really high impedance it might be loud enough.
I consider most of the stuff in this thread to be audiophile BS, I can only suggest to try the stuff yourself.
