Anyone here tried Cozoy Trakt Pro btw?
There is a shop that sells this. I will go try demo probably in this weekend.
Btw, have you tried Marshall London vs XP6?
Each of us has its own ears it seems. I own both XD-05 and LG V20 and I don't remember a marked difference in sound quality to the benefit of XD-05. Rather the opposite. I don't have DT880 250ohm to test, but DT990 Pro (same 250ohm) and others from AKG, Sennheiser, Fostex or Audeze.
Now if you just test with 300+ohm headphones, or hungry planars, maybe xduoo works better because amping is more powerfull. You should try a blind test, with sound volumes matched. And listen to microdetails.
My Meizu Pro 6 Plus is far superior than my M2S.
Update Meizu 15/Plus and Huawei honor 10 in google doc link.
Anything I miss lately?
Wow... Why is it better ? Or how is it better? Curious to know
By the way I can see that you got the imr r1. Can you tell me a little bit about it? And if you could compare it to the Sony ex800st?
I think it has the standard snapdragon, I personally like the sound outcome with my kz zs6 but definitely need the amp for the kz zs10 as the sound is not as good without itDoes anyone know what specific dac nokia 8 has?
