korzh
- Jun 6, 2016
Vivo Xplay is only for chinese market and it never sold my its owners, cause phones is legendary
I cannot believe that somebody else has finally given the credits that Focal Listen Pro deserve. Having wasted over 10 thousand hours of reading no less pages, and tried most headphones in Cobra showroom in Paris... I have always felt that these headphones are something quite special. So many 5 star headphones sound pathetic, compared to them (Beyerdynamic Amiron, P7 - laughable)
And, would you believe it, I want to buy the Xduoo Link 2 Bal which you own. I beg you to try Focal Listen Pro with it and share opinions...
As for Vivo phones, the only ones I could find in Bulgaria are from the Y-series, namely three models, Y72 / Y70 / Y33s. Is any of those worth it, purely for audio, compared to what I currently have, please?
Which brings me to my problem. I indeed have a V30 and have been told by my carrier that I need to buy a new phone, they are ending support for some of the calling features.The LG V30's quad dac is still amazing considering it's 5yrs old now - still better than many dongle dacs out there. My only exception is Cayin's RU6 which is simply outstanding. I'm swinging towards R2R dacs now I think. But that's just my opinion.
All phones that you have way more less quality than vivo xplays.
Carrier is T-Mobile, and I'm looking at midrange Android phones with SD card support, so no OnePlus 8, etc. The new Samsung A53 (Samsung is not immediately my first choice, I find the UI clumsy) is due out today and tomorrow (depending upon source) but it has no headphone jack at all.
I'm not looking for absolutes here, just a "best choice" option for something good under $550 T-Mobile price; I no longer listen as much as I did so I'm not going to split hairs on getting the best. Willing to go with a reasonable dongle option + a reasonable phone, I personally don't see the intelligence of spending $1100 for the newest & greatest 2022 phone just for it to be worth half that a bit under two years later.
Thank you in advance for your feedback!
Just unplug the left cable of the Sundara and connect the headphone cable to your G7, this should force aux mode automatically.My hifiman sundaras are quite quiet on LG G7 thinq, should I buy a short extension cable and do the trick with impedance that way or is there any other sollution?
Thank you kindly for the reply.Have you looked into the LG V60? It's still 've seen Refurbished ones go for $190-$250 and Open Box offers going for 300 bucks on eBay.
If you want to take a gamble I'm currently sporting an unlocked LG V50 which is also technically unsupported by T-Mobile (these probably are going for $150-$200), but I can still make calls and browse the web on data so far despite the warnings. This might be the same case for the similar G8X, but I'm not completely sure since I don't have one.
The ROG Phone 5 is another great option, but that's a current flagship gaming phone so that's probably beyond your budget.
If you're just looking for solid phone with a headphone jack to pair with a decent dongle-DAC (KA3, S9 Pro, RU6, BTR5, etc.) the Samsung Galaxy M51 is the audio enthusiast phone to beat right now since it has a huuuge 7,000 mAh battery that lasts 15 hours of light use on a charge (6-7 of "screen on time" = 1 day of use). You can find them on eBay right now for $400-$450.
A full list of phones with headphone jacks that I keep updated is listed under Section #2/MNVO Matrix HERE
Can you please let me know about what impedance adapter are talking aboutMy LG V10 and G7 Thinq are significantly better with a DUNU impedance adapter, compared to AUX extensions. The difference is jaw-dropping, even on budget headphones like Focal Listen Pro. This is why I bought a bunch of adapters, although I was reluctant in the beginning.
I have not been able to find confirmation that the Rog Phone 5 bypasses Android SRC. I searched a few days ago. Would you mind pointing me to the resource that confirms it? Whatever it is, even user screenshots.Actually two do: The LG V60 and ROG Phone 5.
https://www.head-fi.org/threads/lg-v60-thinq-smartphone.926477/post-15726759
https://rog.asus.com/in/phones/rog-phone-5-model/wtb
Thanks for mentioning this phone. Added it to my list of US-compatible phones with headphone jacks.
I do things slightly differently. I also use a 3.5 male to male adapter with no impedance. The procedure is:Certainly! I bought the 75 Ohm one, but there is also a 30 Ohm version, both in metal housing. I find it fairly durable, as I have pressed it very hard, without bending it (using it on the go in public transport...where I broke two cheap, plastic adapters). First, connect the adapter to the 3.5 jack of your headphones. Then, when everything is ready, plug the cable with the already connected adapter in the phone. Before, I had plugged the adapter into the phone first...and the result was unimpressive. I tried the 75 Ohm adapter with LG V10 and G7, with all my headphones: Focal Listen, CCA C12, some cheap HTC bundled-handsfree, Focal Listen Professional and Sennheiser HD 599 SE (the latter triggers High impedance mode everytime, without an adapter). Needless to say...the WOW factor was there everytime. I had read on this forum about the DUNU adapter, and I am happy I bought some:
https://www.aliexpress.com/item/32822361714.html?spm=a2g0o.productlist.0.0.1d2d12b5Raigs8&algo_pvid=6e139a3a-4d10-4c4a-8619-987d6b24dfca&algo_exp_id=6e139a3a-4d10-4c4a-8619-987d6b24dfca-1&pdp_ext_f={"sku_id":"12000020979159267"}&pdp_pi=-1;32.9;-1;-1@salePrice;BGN;search-mainSearch
Thanks. Yes, I am the same - I like to fluctuate between V30, HTC 10, Dragonfly Black and Cayin RU6. Overall, I think I do prefer the V30's quad dac vs HTC 10 and Dragonfly; however, I'm really loving the RU6 since purchasing. Has me curious about R2R dacs. It is the benefit of a hobby like this - going back and forth between equipmentMy old HTC 10 gives a run for the money of LG V10 and G7...until one listens to the treble extension and starts missing the details in it. The sound is fuller, more fun, more analogue, but..something just is not there. Sometimes I take the LG, sometimes I take the HTC out for a long walk, depends on the mood, but especially with DSD (that are actually vynil scans), G7`s newer DAC shines. Otherwise I prefer V10 of all three.
