Andricop
- Nov 12, 2010
Sorry to ask but what is the point to have a dedicated DAC if there is no jack? If you need to use an USB-C to jack adapter, it's the adapter's jack that will convert the sound.
I think you may be right. I'm listening to dongles using my Shanling M0 and Q1 and I swear the device and the dongle are splitting the SQ by what each of them want to do with it.Sorry to ask but what is the point to have a dedicated DAC if there is no jack? If you need to use an USB-C to jack adapter, it's the adapter's jack that will convert the sound.
Remember that digital signals are far less prone to changes in sound by the the cable/connector used than analog signals.Sorry to ask but what is the point to have a dedicated DAC if there is no jack? If you need to use an USB-C to jack adapter, it's the adapter's jack that will convert the sound.
I'm no expert, but I would suspect that if the phone has a DAC, it may convert before going to the dongle. It's possible the adapter is literally changing from USB to 3.5mm or equivalent.... what is the point to have a dedicated DAC if there is no jack? If you need to use an USB-C to jack adapter, it's the adapter's jack that will convert the sound.
Agreed, but in this case it's the built-in DAC of the BT earphone/headphone that is usedIn addition, don't forget many people are using Bluetooth and not any kind of cable
If they volume isn't loud enough for you, you're going to need a headphone amplifier. A simple USB C to 3.5mm dongle you pick up at Amazon for a few dollars probably isn't going to work since they're not going amplify (add power) to the signal.My hifiman sundaras are quite quiet on LG G7 thinq, should I buy a short extension cable and do the trick with impedance that way or is there any other sollution?
Luckily that are plenty of amplifiers and DAC/amp combos to choose from. It's a matter of budget and what your needs/wants. The Chord Mojo is a few hundred dollars, but I believe it will have the power to run planar cans very well. There is a new version, Mojo 2, recently released too. There is a FiiO BTR5, significantly cheaper, and very small, that probably work. I think Sundras can run balanced. If correct, get the appropriate cord and some of those portable amp/dacs have more power to run the headsets, usually, better.
There are others with significantly more knowledge and experience than me who will be able to provide actual recommendations and better details.
I mentioned mine did. And have since received a January security patch (on Rogers in Canada)DAMN IT! T-Mobile upgraded my LG G8 ThinQ to Android 11 this week. If I knew that was going to happen I probably would have held off getting my Samsung Z Fold3!
