@artpiggo
Just one more question for enlightenment - say I get the grado, how can I check if my phone can drive it? What should I look for? Just point me in the right direction and I will do the research!
nothing can tell better than your ears.
@artpiggo
Grado are usually easy to drive (often 32ohm impedance). What kind of phone do you use, and what grado model are you interested in ?@artpiggo
Concerning the "bit perfect" topic and the issue with the standard 48khz sample rate used by android:
On rooted devices it is actually easily possible to change it to 44.1khz.
The sound quality is imo very close to using uapp then.
I did it like in the following youtube video:
I only found two places where the value was 48000 and changed them to 44100. Worked according to the "bit rate" app from play store.
Is a great way to improve spotify spotify quality.
https://www.head-fi.org/threads/music-apps-tips-and-tricks-for-the-lg-v30.868978/
"LG made a staggeringly bizarre oversight in the implementation of the V30's DAC, which cannot natively support 44 kHz, 16 bit files"
Just use neutron and uapp for tidal/qobuz
Would this method provide "bit perfect" playback of 16 bit 44.1 KHz music files.I.e. Qobuz and or Tidal Offline music?.
