I use my HD 650 with the Valhalla/Bifrost Uber combo and I am very happy with the sound.
Best Schiit Amp for HD 650?
- Thread starter jfdelacruz
kamikazi
- Aug 12, 2012
Right now i just use the Yunlong D100 mark 2 to drive my hd650
I'm try to find an upgrade, to Schiit too, or maybe use d100 as dac then get a Lyr 2 or vahalla 2 for an amp
Would you guys think that would be good idea or not?
Bugler
- Apr 29, 2014
Sorry double post
samysonary
- Oct 22, 2012
I currently have the Asgard2 with thee HD650s. Love the combo. I like that the Asgard2 is able to drive a wide range of headphones for my future purchases. I am looking forward to purchasing either thee Lyr2 or the Valhalla2 to jump into the tube amp scene. It is going to be a hard decision but you will not be disappointed. Good luck!
Liu Junyuan
- May 22, 2014
Valhalla 2 for HD-650s without question. The Ly2 and Asgard 2 would compete for second choice.
servicenow
- Dec 28, 2014
Does it also pair well with T1 ? I mean Valhalla 2 ?
Ttvetjanu
- May 15, 2005
I'm considering between Valhalla 2 and Asgard 2. I will be using the meridian explorer2 as my source, it already has amplification so what I'm wondering is if that will it make it easier for the Asgard 2 to drive the HD650's. I basically have no idea on how multiple amplifications work together.
guildenstern
You have probably already read this review, but if not, then Steve G on CNET likes the way the Valhalla 2 works with his T1s:
http://www.cnet.com/news/the-little-schiit-headphone-amp-makes-a-big-sound/
Liu Junyuan
- May 22, 2014
Sorry for the delayed reply. Of all the $500 and below Schiit amps, the Valhalla 2 would be my top pick for the T1; it drives the most voltage into 600 ohms of any of the others.
dL.
- Dec 29, 2009
What makes the Lyr 2 more versatile and future-proof than Valhalla?
dL
dL
worminater
- Mar 29, 2005
Lyr has a bit more power; so you could use it with more power hungry cans. I myself chose a Valhalla though as I was more worried about the opposite.
Leisure Muffin
- Mar 28, 2015
I'm confused, the output impedance of the Valhalla 2 says it is only 14 ohms. The HD 650's have a 300 ohm impedance that needs to be met to accurately push them. Am I missing something? Is it because the Valhalla 2 is Output Transformer-Less?
TinearedOne
- Feb 23, 2015
Minimum desirable output/input impedance ratio is 1:10, so optimal for Valhalla/HD650 which is 1:21. The 14 ohm output is why they had to put the gain switch on the Valhalla 2 to drive low impedance cans more effectively, because 1:2 or 3 doesn't really cut it.
Leisure Muffin
- Mar 28, 2015
Hmm, I'm still confused. Could you explain it to me like I'm a 9 year old with a head injury? I thought that the ideal was to get as close to 1:1 as possible for high impedance headphones because they are resisting the flow, and need something to push back equally to get the most accurate representation of the source material.
Rem0o
- Jan 10, 2013
Let me quote myself as I tried to explain how this whole impedance thing works:
An amp is a really dumb device. Like a guy, it can't focus on two things at once, or at least, do two things right at once. Also, it always focus on the bigger thing. "Big = get my attention" kind of logic. The "things" in this scenario are loads (resistances/impedance). By itself, an amp has a real small thing to exclusively focus on, its output impedance. It will drive all of its attention (voltage) to it. When you show him a bigger load (headphone), it will shift its attention to this new huge thing. However, he will always focus also a little bit on its poor and lonely little output impedance, making him work on two things at once, hence bad (remember, it's like a guy). As it tries to drive two things, it will lose focus and mess with both, doing poorly. The trick here is to make either:
A -> The headphone load so much more interesting (making it BIG like 300 ohms ++) than the output impedance so the amp will almost exclusively focus on the headphones.
or...
B -> Make the output impedance boring and not interesting (making it small) so whatever else you show the amp (low-impedance headphones), it will exclusively focus on that.
And that's how an amp work. "
