Best IEM tips?
- Thread starter lilboozy
zenki
@smith, @KnightCaeli jp stores.
Marunana is basically jp spinfit at a fraction of price. Really2x good. Soft + flexible all around (easy to fit into larger nozzle). Regretting of not buying more...
AEC is really comfy, totally didn't expect that for cheapies.
Nuarl tips is pretty much like spiraldot
JEHL
I wonder, has anyone ever achieved a seal while the tips are barely in the ear canal at all? Apparently I got that with:
Sadly I have no idea where these tips come from... How they arrived to my doorstep is a mystery to me.
Because of such shallow insertion you'd think I'd lose on bass extension... turns out I get about 20Hz more extension than any of the stock tips I've tried.
Also can anyone estimate the bore diameter by looking at them? I have no idea how to measure this and I don't have anything to measure this anyway.
DBaldock9
You're actually holding something that can be used as a reference measuring tool - because the diameter of the ferrule (locking ring) on the MMCX connector is ~3mm.I wonder, has anyone ever achieved a seal while the tips are barely in the ear canal at all? Apparently I got that with:
JEHL
I tried using the bottom of the cable plug since that's apparently 4.4mm, although all I can figure out from this is that it's wide enough that the bottom of the jack goes though.You're actually holding something that can be used as a reference measuring tool - because the diameter of the ferrule (locking ring) on the MMCX connector is ~3mm.![]()
SilverEars
- Sep 18, 2013
- Messages
- 10,947
- Reaction score
- 4,532
Recently got to try out EARTUNE FIDELITY U, which is the one with oval shape.
Their largest size called large wasn't large enough to fit me ears. They need to make an XL. Generally, I require larfe size tips.
I don't see how oval shape can work. I was confused how the oval should be oriented.
Although due to fit I couldn't assess properly, I found the highs to be improved by these. Perhaps it's due to the angled outlet at the end of the sound canal?
assassin10000
The majority of ear canals are oval shaped and have the top/bottom as the long side IIRC. Ymmv, in angle and shape, as everyone's ears are shaped differently.Recently got to try out EARTUNE FIDELITY U, which is the one with oval shape.
IEMusic
Align the oval vertically when you insert them. Of course that won’t make them any larger. Maybe try them with IEM’s that have a deeper insertion, just to see how they fare in that scenario.Recently got to try out EARTUNE FIDELITY U, which is the one with oval shape.
SilverEars
- Sep 18, 2013
- Messages
- 10,947
- Reaction score
- 4,532
Alignment isn't simple with a fixed orientation due to not knowing precisely how the iem will be oriented when on the canal.Align the oval vertically when you insert them. Of course that won’t make them any larger. Maybe try them with IEM’s that have a deeper insertion, just to see how they fare in that scenario.
I guess if the size is smaller than I use normally, I guess deeper insertion iems could work, but I don't have any iems that are deep insertion. When I think of deep insertion, I think of ones that require triple flanges like Etys.
RONJA MESCO
- Jul 22, 2017
- Messages
- 523
- Reaction score
- 256
thanks for this because I am finding that the CCA's are so particular (crashy highs and whatnot) ...I am trying to find the right tips for these before I make a decision to send them back or not...Going to give these a shot on my CCA CA16. Not primarily for a sound variance, more so for retention. As my Tennmak Ultra Strong tips sometimes choose to stay in my ear canal.
Linsoul Tripowin Spiral Groove Memory Foam Eartips
Link to Amazon
The Linsoul Tripowin Spiral Groove Memory Foam Eartips ended up in my drawer of regret. The rebound time of the memory foam is on par with a senior citizen, in the Express lane, at the grocery store. I had to actually hold the CA16 in place, for more than 15 seconds, while waiting for the tip to decompress, in my ear hole.thanks for this because I am finding that the CCA's are so particular (crashy highs and whatnot) ...I am trying to find the right tips for these before I make a decision to send them back or not...
SilverEars
- Sep 18, 2013
- Messages
- 10,947
- Reaction score
- 4,532
Here's the back of the packing with information about EARTUNE FIDELITY U in terms of shape and dimentions. I do think there is something to the way the bore outlet is angled. It is 4mm wide, so wide bore which I think is a good width. I think this angled bore outlet causes better quality highs.
However, I don't believe oval shape design will work. With round designs, the silicone will adjust to the contour of the canal shape. With oval, you don't know if you have placed the oval precisely to fit correctly. Chances are much greater with oval shape to have wrong fit because the fit depends on the orientation of the tips.
IEMusic
FWIW, I get an outstanding seal with my Klipsch oval ear tips. I‘m able to just insert them vertically, and they may rotate slightly to conform. HOWEVER, the Klipsch IEMs are “bullet-shaped”, with a straight insertion, so I am able to push them in as deep as needed to get a good seal.
LostInDaSauce
Hi im a beginner but would like to post my thoughts on 2 tips orderedm the tennmak ultra strong tips and AZLA xelastics medium 3 pairs on amazon after some earlier reviews.
Xelastics
Expensive but nothing else like it $30 usd amazon 3 pair
sticky
Actual size is definitely larger but i dont know if I recommend getting a full size smaller..
As someone else said before, seal of a foam tip but acoustics of silicone - rings true for me.
Get dirty very easily but cleaning seems easy too.
If youre having a hard time putting them on due to their sticky surface you can slightly damp with some water to help getting it fit in
Tennmak ultra strong
Cheap $7 usd amazon 6 pair
Some type of slippery oil applied to them?
Should be named ultra soft- reallly slow rebound time if any
I felt the stem of my iems that caused pain in ear after prolonged use. Might just be me having this issue though
Both sound great to me and i wont be returning either of them but would give overall sound xelastics takes the cake
if youre looking for expensive unique silicone-xelastics, (medium recommendation)
if youre looking for budget super soft foam, tennmak ultra strength (weak recommendation)
Xelastics
sticky
Shure oliver are most comfortable ones
