May 9, 2025 at 2:09 PM Post #3,916 of 3,919
@pawdiophile I'm impressed with your test.
If I am looking for tips:
1. with the widest possible bore, but so that there is no narrowing inside the barrel
a straight barrel from the insertion lip to the barrel.
2. at the same time, so that these tips are short , and the softest
Am I interpreting your description and photos correctly?
Which of these tips might be closest to what I am looking for?
No. 1 - TRI Clarion?
No. 2 - Divinus normal bore ?
(I know there is a version of them Dizinus Wide but it is a strange shape of the tip and they have a narrowing in barrel)
I also have a whole collection of tips but narrow, I am looking for an alternative to the original tips for the Oriolus Szalyi IEM - wide bore ,short nad soft.
May 10, 2025 at 9:25 AM Post #3,918 of 3,919
Tri Clarion might be what you're looking for. Wide bore and short. I currently use them with the Kiwi Ears Punch. You might also want to look into a set of original JVC Spiral Dot. Not as short, but wide bore.
May 10, 2025 at 12:26 PM Post #3,919 of 3,919
When writing JVC Spiral Dot which model are you thinking of,,which has the widest barrel along its entire length:
EP-FX-9M-B, EP-FX10,EP-FX11 or EP-FX12 there are several models.
Manufacturers also do not help by stating that you can put on a tip from 4mm to 6mm with a large tolerance.
I will also stretch a very narrow tip, no, that is not the way to make it deformed. That is why I am looking for the widest possible but short one.
