Carpet
One for each ear or are we talking about threading them up like beads to make a necklace?5 IEMs and 40 pairs of eartips seem reasonable for a 2-week travel.![]()
![Prayer beads :prayer_beads: 📿](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f4ff.png)
I bought from Amazon,jp. (To Norway).Does anyone know where I can purchase CanalWorks eartips and have them shipped to the US? Obsessively trying lots of eartips recently and they're high on my list.![]()
Have you tried the Comply T-500s?If you have, how do they fit vs silicone tips ( ie same size or use a size smaller/larger)? I can’t seem to find foam tips that stay in my ear for more than a few minutes, the exception being Symbio W which are a foam/silicone hybrid. I am thinking of trying the T-500s out, as they look longer than most foam tips, which I am hoping will result in them staying in my ear longer.Ha. Yeah. All too familiar. The Comply tips work fantastically with the unvented Symphonium Meteor. Buuuut... the day before I left home for my summer travels, I was getting a great seal with my Divinus Velvets, so I started thinking, "Maybe I just didn't give these a proper chance." So I left the Comply tips at home and packed up the Velvets instead. You can probably guess how that turned out. So, yeah, for the past two weeks, it's been a maddening exercise in perfectly balancing them in my ears to get a passable seal. Now I'm stuck with just these tips with the Meteor for six more weeks. Ugh.
Thankfully I packed a couple other IEMs, but it doesn't prevent me from futilely trying to get a good seal with the Meteor + Velvets!
Soundwise, I do like the Eletechs a lot more. It's very balanced and sounds very energetic and clear compared to the Azleas which sounded a little boomy which I can only attribute to the wax guard being a physical veil between the ear and nozzle.
Yup. They were the magic bullet for an especially tricky set of IEMs. Like you, I was skeptical of trying more foams because all the foams I had tried before were all too small for my ears. I obviously can't promise they'll fit you like they do me, but the Comply 500s were the solution for me to a very extensive and challenging search.Have you tried the Comply T-500s?If you have, how do they fit vs silicone tips ( ie same size or use a size smaller/larger)? I can’t seem to find foam tips that stay in my ear for more than a few minutes, the exception being Symbio W which are a foam/silicone hybrid. I am thinking of trying the T-500s out, as they look longer than most foam tips, which I am hoping will result in them staying in my ear longer.
Thank you! I just ordered the variety-sized pack and am hoping for similar success. I really appreciate your input.Yup. They were the magic bullet for an especially tricky set of IEMs. Like you, I was skeptical of trying more foams because all the foams I had tried before were all too small for my ears. I obviously can't promise they'll fit you like they do me, but the Comply 500s were the solution for me to a very extensive and challenging search.
I thought the nozzle width was the only difference with all the Comply models - eg T500 being wider than T400. Am I wrong? It's a shame they provide so little information on their website.Have you tried the Comply T-500s?If you have, how do they fit vs silicone tips ( ie same size or use a size smaller/larger)? I can’t seem to find foam tips that stay in my ear for more than a few minutes, the exception being Symbio W which are a foam/silicone hybrid. I am thinking of trying the T-500s out, as they look longer than most foam tips, which I am hoping will result in them staying in my ear longer.
Totally. I envy people who get to choose their ear tips solely based on how they sound. For the rest of us, the order of priority in choosing a tip is 1) getting a good seal, 2) keeping a good seal, 3) comfort, then 4) sound quality.The key to the eartips game is getting the best seal as possible for a given IEM. Then, followed by comfort, i.e., for how long this seal can be sustained.
I bought 4 different ones, ...
Not sure if I broke them, but it looks like the outer plastic is coming lose from the foam underneath.
Yep, that's a known issue. This even happens with the more expensive Symbio W ones.![]()
