two different sized tips in the left and right ear due to this anatomical variance!
Maybe I should try this
Maybe I should try this![]()
I prefer to use single size pairs but it’s true that I can sometimes get a better overall fit with an L in my left ear and an M in my right.
Just do it!
I have another question and hopefully someone can help me with it: I am looking for an alternative to the Final Type E with a little less bass and a little more treble. According to this reference https://www.audioreviews.org/guide-to-iem-silicone-eartips/ the SpinFit CP100+ and SpinFit W1 would be ideal. Does anyone have experience with these - perhaps with a comparison to the Final Type E? I have the oldest version of CP100 here, but I find the bass is just missing. Is the new one actually different?
The TRI Clarion might be the solution for you. They available on AliExpress.I have another question and hopefully someone can help me with it: I am looking for an alternative to the Final Type E with a little less bass and a little more treble. According to this reference https://www.audioreviews.org/guide-to-iem-silicone-eartips/ the SpinFit CP100+ and SpinFit W1 would be ideal. Does anyone have experience with these - perhaps with a comparison to the Final Type E? I have the oldest version of CP100 here, but I find the bass is just missing. Is the new one actually different?
SpinFit CP100+ blew me away with the clarity of the mids and highs but I agree they have almost no bass. I tried the AZLA SednaEarfit Light and Crystal Standard and am very happy with both, though I do sometimes want to boost treble with EQ a bit using those after hearing what's there in my music that I never knew was there until I tried the SpinFit CP100+. I decided to go with AZLA rather than boost bass with EQ with the SpinFits, which didn't seem like the best way to get an uncompromised bass since they just aren't great at reproducing bass. I guess either way would work: use AZLA and boost treble in EQ, or use SpinFit and boost bass in EQ. All in all, I'm staying with the AZLAs.I have another question and hopefully someone can help me with it: I am looking for an alternative to the Final Type E with a little less bass and a little more treble. According to this reference https://www.audioreviews.org/guide-to-iem-silicone-eartips/ the SpinFit CP100+ and SpinFit W1 would be ideal. Does anyone have experience with these - perhaps with a comparison to the Final Type E? I have the oldest version of CP100 here, but I find the bass is just missing. Is the new one actually different?
Maybe I have a very bad wide bore eartips, but for me none of them can give more bass than narrow bore gives, especially in a physical feeling of bass. I'll try T300T and T300B in the future, but for now, I can't hear the same thing, and even Spiral Dot can't outbass the typical bassy narrow bore tips - like KBEar 08, for example.Why is it that the less the air in the front the more the bass? In a 2 channel system, the relationship between amount of bass and the room size is probably non-linear. It also has to do with the frequency of bass, I suppose. See, for example, this discussion. The effect of end correction, on the other hand, is linear: the wider the bore, the lower the resonance frequency.
Anyway, look forward to what you think of T300T vs T300B. There are spinfit models that are identical-up-to-bore-width too, fwiw.
Well if the bass hit is compression of air in the air canal, then the smaller the volume, the greater the compressive effect of air being pushed out by the transducer. Presumably more so for dynamic drivers than BAs. Dynamic driver is more akin to using a plunger to unblock a sink, BA placing a speaker next to it.Why is it that the less the air in the front the more the bass? In a 2 channel system, the relationship between amount of bass and the room size is probably non-linear. It also has to do with the frequency of bass, I suppose. See, for example, this discussion. The effect of end correction, on the other hand, is linear: the wider the bore, the lower the resonance frequency.
Try eartips that come in a greater range of sizes S,M-,M,M+,L. That gives you a bit more room to fine tune for size variance. Remember if you do find a match that way you will have 2 sets from a mixed set (plus a few pairs in other sizes for friends)*Yes physics play a large part, but one factor often overlooked is that eartips are as personal as shoes, due to our different ear anatomy - this affects seal and fit, and hence the sound. So what someone finds tames the treble may not necessarily work for others. It is also not uncommon to find consumers needing two different sized tips in the left and right ear due to this anatomical variance!
But as a general rule of thumb, foam tips mostly will tame the treble.
Narrow bore tips or longer stem tips/deeper insertion generally tame the treble more. Exceptions exist of course. YMMV.
Spiral dot vs 08 is wide+matte vs narrow+glossy. Gotta control for the variables and find a wide+glossy (like T300T) or narrow+matte (like Sedna original). 08 has great bass, and overall is incredibly loud, but a wide+glossy tip would have less uppermids, and hence more (relative) bass volume.Maybe I have a very bad wide bore eartips, but for me none of them can give more bass than narrow bore gives, especially in a physical feeling of bass. I'll try T300T and T300B in the future, but for now, I can't hear the same thing, and even Spiral Dot can't outbass the typical bassy narrow bore tips - like KBEar 08, for example.
