dentnu
- Jul 16, 2012
Which shape ?
Pics please.![]()
Which shape ?
Pics please.![]()
OK, foam. So it is a "special" case...
What doesn't fit you, or miss ? What's wrong with those foams?
Thanks for the reply. I have a set made by New Bee that I have worn a couple of times when I first got into IEMs. I preferred the feel of silicone but foam tips might be the only option I have. What about Sedna? Worth trying or just more silicone?
Well they work fine I guess. I pretty new to the IEM myself. I have heard of different tips made of silicone etc. not sure if those are better. Just want to try out some other tips to see if I would like them better then the foams that I have. Thanks
Finally an Ear Tip Guide on YouTube.
Awesome thanks for posting the link. Was not really convinced after warching the video as like you said most of them are spinfits.20 minutes for just 4 brands and 7 of them are Spinfits...
https://www.audioreviews.org/guide-to-iem-silicone-eartips/
That link is a real complete guide. Its constantly updated. Clarion and Fiio HS18 recently included, by the way
OKWell they work fine I guess. I pretty new to the IEM myself. I have heard of different tips made of silicone etc. not sure if those are better. Just want to try out some other tips to see if I would like them better then the foams that I have. Thanks
KBEAR 07 are worth a try, they come in 5 sizes which can help getting a good fit. I used to use SpinFits ( CP100 or CP145) until I got the TRI Meteor which came with these. These sound better to my ears and are way cheaper, $8 for 5 pairs. These are the same as the AET07 ( apparently there is no translation for "intellectual property" in Chinese).Can I get some tips recommendations ? I am currently have the Audio 64 U12t and am using the stock tips. Would like to try out some other tips to see what would work best for me. Thanks
Yes, agreed. There really is very little information about the nuances of tip rolling out there, surprisingly. This helps.Awesome thanks for posting the link. Was not really convinced after warching the video as like you said most of them are spinfits.
