Drag0n
- Jun 11, 2004
Really everyone likes a different presentation, but any Grados....although 225 and RS1 got the rep for rock, but dont discount the closed $150 M-Audio Q40 for rock too!!!!
Originally Posted by Hipstergarabe /img/forum/go_quote.gif Thanks, all. I've narrowed the choices down to the SR325is and the AD900 - both look pretty perfect for my music, I'll have to do a little research before I order anything. |
Originally Posted by jaycalgary /img/forum/go_quote.gif I see it as more people over exaggerate how bad the K701/2 is they even make up new terms for flaws. |
Originally Posted by Acix /img/forum/go_quote.gif I'm sorry for your AKGs flip. |
Originally Posted by Kernmac /img/forum/go_quote.gif Grado's are the best? AKG is no good for rock? _subjective generalisations. The problem with these types of thread is in the initial question-"What is the best for .........?" No offense to the OP, as it is a very common question. There is no best. It is all about different flavours, different preferences, different presentations and focus. Is a banana a better fruit than an apple or an orange? IMO it is naive and a massive generalisation to say that Grado is "Best for all rock" and model x, or even worse brand x isnt. Define best for starters. It is better to decribe the sound signature you seek and then get advice regarding headphones that fit that signature type. Grado is in your face, forward, lacks soundstage (both width and depth) focuses on the midrange and some do not like the high end (find it piercing apparantly). Now a lot of rock music doesn't rely on soundstage but some does. Rock is a little "in your face" at times but as Acix quite rightly points out, accoustic and ballad rock types are more laid back. If you like forward in your face then Grado might be for you, however if you don't then look elsewhere. There is no one type of headphone that is "best" for any genre IMO, identify what you like (bassy, not bass centric etc) and then look for the fons that fit what you like, your preference. By all means take into consideration the genres you listen to most, but don't get caught like a dumb sheep (no offence to grazing animals) in the Grado only for rock brigade, or K701 only for classical or jazz or whatever. To the OP, Grado SR325i (I have only had MS2) or AD900 are both great fons and probably good choices, but they are very different from each other and you may like one and not the other. Think about what you seek before you purchase, and obviously if you can listen first there is no substitute to trusting your own ears. |
Originally Posted by Silenced /img/forum/go_quote.gif True. But I think when grado designs a headphone they have rock in mind. Whereas Sens are usually tuned for classical. |
Originally Posted by Rayz /img/forum/go_quote.gif K70x are surely isn't the best choice for rock because k70x are amazing when it comes to detailed music, what means heavy rock\metal (the most non-detailed genre one who has high trebel without much details) will sounds pretty bad with k701 . I'd say- any genre sounds good with K70x but hevay rock. Look, It's not that k701 are the worst choice for heavy rock- it's still sounds better than a lot of phones Iv'e heard. But I would recommended for high-bass phones (in your face, like people said) for heavy rock\metal like HD650. Good luck. |
Originally Posted by glrtrgi /img/forum/go_quote.gif How do the Grado HF-2 cans rate in terms if listening to R & R? |
Originally Posted by Hipstergarabe /img/forum/go_quote.gif So, I think the AD900s are what I'm going to go for. The comments about the Grados are kind of intimidating, and I can get a great deal on them, so. Thanks all. |
